Air Suspension - AGAIN
The "crystals" are molecular sieve and can be regenerated in an oven
but new ones here:
https://www.silicagel.com.au/molecular-sieves/4a-4x8
but new ones here:
Thank you very much gentlemen for all the help and advice. The whole job took me two days to complete (I am 81 and not so nimble under cars anymore). The most difficult part was in fixing the compressor back up into the car. My X350 has the two horns right where you need your hand to hold the washers/spring/nut assy. The video Jaroslav posted (very helpful) is on a X358 and does not have the horns in the same place. Anyway, after much struggling and swearing (such as "this is unfortunate") I concluded that a special tool would be needed. First, I glued the upper most Top hat piece to the stud with just a tiny drop of super glue to hold it in place (see picture) Then with the aid of my tool was able to both hold the compressor (with the aid of a chock) up and place the spring and lower top hat washer/nut assy. Everything else was straight forward and after a test run without any faults showing I deemed it "Mission accomplished".
Chock holding up the washer assy whilst the glue sets.
Special tool.
tool closeup
Special tool.
tool closeup
TommyBoah (02-11-2024)
Bob Hornby (02-12-2024)
SuperJAY
12-09-2023 01:52 AM
superfisch
05-02-2022 02:29 PM
