For the last couple of years I have been trying to get my compressor fault code C2303 & C1830 resolved. I had tried the compressor ring kit found on Ebay, but quickly found that the piston cylinder was too worn for that option to provide a long term repair. I tried to shim the ring, but no luck. Then, just when I thought I was stuck buying a new compressor I finally found the piston cylinder. These folks, ca_axle_parts on eBay have a cylinder head and that combined with the ring kit from lrnj_autoparts on eBay
I have no more fault code, the suspension airs up like it should and it holds the air. The cylinder fits several models of vehicles so do not be alarmed when Jaguar is not the primary name with the part. Ring Kit Jaguar Compressor Air Compressor Piston chamber
Thanks for the helpful tip on the replacement cylinder head. I'm sure that will help others. I just searched those sellers listings and found the piston ring kit from lnrj_autoparts, but I couldn't find the cylinder among the items for sale by ca_axle_parts by searching common terms like "compressor," "cylinder," or their apparent term, "piston chamber." Can you provide direct links to the listing?
