air suspension error to high
Reservoir plausibility error is C2303, and you can measure the ride heights from the fender (wing) arch to the wheel center to see if it is actually too high. Front spec is 371 to 401mm, rear spec is 358 to 388mm. I just measure to the middle of the cat's face.
There is a calibration that can be done to calibrate the ride height. However, that code has been linked to the compressor failing, unless you have any other related codes logged. Try doing a calibration, which needs to be done using SDD and see if that helps, if not, the compressor for the air suspension is most likely starting to fail.
MK2
05-12-2016 04:44 PM
Vector
US Lower Atlantic
03-13-2016 04:07 PM
