air suspension fault
Old 10-13-2017 | 11:18 PM
dontono's Avatar
Default air suspension fault
dash light comes on and screen reads "air suspension fault", XJ8L, 2005
Old 10-14-2017 | 12:10 AM
abonano's Avatar
Forum search
Old 10-14-2017 | 01:57 AM
woox4's Avatar
Get the codes read.
Old 10-14-2017 | 05:17 PM
Fraser Mitchell's Avatar
If the car seems to have correct ride height but ride seems harder than usual, you will probably find one of the fault codes is C2303. This is an indication of the air compressor starting to wear and hence taking too long to recharge the reservoir. I had it on my last X350 (now on my 2nd), and a new compressor was a complete cure. In fact the new compressor took me from 2010 and 35k miles to 2016 and 115k when I part-exed it for a Sovereign, and still working OK. I was told late last year when talking about the air suspension to an ex-Jaguar tech that early compressors failed rather quickly and later ones were better. However your car is a 2005, so maybe you can tell us what miles are on the car bearing in mind is is now 12 years old.
Old 10-16-2017 | 09:26 PM
dontono's Avatar
my Jag has 89000 miles, and I tried reading the codes with a reader and told me that P1111 was ok. This is the only code that was pulled.
Today I noticed that the left side is higher than the right side to both tires. Does this mean that new shocks are needed? And if so where can I get them 'cheap'?
Old 12-20-2017 | 08:26 AM
carelm's Avatar
Yesterday I got the dreaded "Air Suspension Fault" message. I didn't notice anything different about how my car rode though. After a short lunch I got the same message as soon as I started my car which lead me to believe it really wasn't suspension related. I did some research and there is a tech bulletin on how to diagnose the issue (see link). Anyway, the first step is to do an ignition On/Off twice to clear the code. I did this and the offending message went away.
http://www.jagrepair.com/images/TSB/...iagnostics.pdf
Don B
General Tech Help
17
08-08-2017 10:11 AM
tweetybird
10-17-2016 04:18 AM
philwarner
10-09-2016 02:08 PM
MickJagguar
10-04-2016 05:26 PM
JimC64
02-13-2014 08:35 PM
Quick Reply: air suspension fault
