Air suspension fault
Hi friends
My name is avraham and
This is my first time here login in i
Loves your answers and the mutually help
I have xj8 2005 .
For several months suffering from air suspension fault.
After changing 4 shocks, not simultaneously ,the problem not slove .
Changing also new battery
Engine brackets
Control arms up &down front
And also repair kit for the compressor 3 years from now.
I' don't have any codes for the suspension fault at the moment
through time when leaks suspension is a cure,I know that
,the compressor working consistently
Do you think that changing kit repair 3 years from now and after compressor working 24/7 ,
The compressor can be the base error for this action?
Do you think that, the repair kit is worth anything ??
Thank you
Avraham
I have xj8 2005 .
Engine brackets
Thank you
Avraham
So, you don't get any codes, but your suspension is leaking air and your compressor is constantly on. Is that correct?
Have you tried spraying a little soapy water on the top of the air struts where the air lines connect? If the seals are leaking you'll see bubbles form where the air is leaking.
