air suspension fault on 2006 xj8
air suspension fault code goes on if 2006 xj8 is left outside on cold night. after driving and then stopping for as little as 30 seconds problem goes away.is it due to faulty compressor or leak in shock.have select edition warranty not sure what is covered any help is appreciated
The component that fails the most often in the air suspension assembly is the air compressor. Service exchange compressors are available at main agents and also on the internet. Fitting time one hour or less if the mechanic knows what he is doing, i.e has done one before.
However, it might not be this, but reading out the fault codes will tell you. Essentially the suspension controller checks for time taken to charge the air reservoir to its defined pressure; if too long, up comes a fault message and light. For some reason, cold weather makes the problem worse. I suppose it could be worn seals in the compressor that are not sufficiently flexible when cold to prevent blow-by the compressor piston.
Anyway a replacement compressor cured my fault.
I am a Jag tech down here in Miami and the compressors rarely go out down here. What goes out all the time is the springs, I haven't seen a Jag that the springs don't go out by 5 years... Could it be because of the climate or I just got lucky? Any Jaguar tech replacing a lot of compressors in similar climate?
Just asking...
Here is a link on how the air suspension works btw:
Jaguar air suspension description
Just asking...
