Air suspension fault
#321
#323
#324
#325
That sounds like bad valves in the valve body in the trunk. If it vents the rears then the vent solenoid in the compressor looks to be OK, as that it the only outlet for excess air to be released. if it won't release from the front, the only other valve needed is the main valve body.
#326
#327
I tend to agree with everything wfooshee (is that the sound of air going out?)
It's unlikely multiple height sensors are faulty.
Going up not down means it's not a leak (except a valve?)
The only "moving part" is the valves (the rest is just sealed wobbly jelly so-to-speak)
Could be control electronics. Can partly test that by disconnecting the battery. You can't then drive, but that's being picky.
I've no idea how you can test a valve block in-situ. Besides, a leaking valve might occur over hours or days/weeks. I reckon the valve block is not given enough protest activity.
I suspect some change shocks when it's actually the valve block. It's my current conspiracy theory (Bill Stein in collaboration with Bill Gates)
Disclaimer: I only have slow "downs" at times, and currently none at all even for weeks. Did nothing. So I reckon the air valves sometimes get a bit of dust interfering with their seal. OR SOMETHING
klfong
44
02-10-2023 02:42 PM
klfong
02-05-2014 06:57 PM
dbrown
17
03-18-2012 04:35 AM
mijohnst
07-18-2010 12:53 PM
