Air suspension in firm mode all the time.
Hi, I have a 2008 XJ8 VP that the air suspension seems to be working properly. No DTC's, compressor (new) comes on and turns off no problems. Car levels no problem. On my I930 diagnostic tool when monitoring the PID DAMPER FIRM ERROR it says NO when parked but as soon as I drive off it goes in YES and the dampers are all indeed firm. I checked lots of things and everything seems to work properly. Wheel speed sensors etc. Anyone have any ideas on this one?Can a height sensor cause this? Not sure what is causing it to go into firm mode. Thanks for any help.
On a 2007 x358 diesel we tried if it was possible to eliminate the coming back transport mode.
I have a 2003 x350 with over 222k miles second pair of struts. After an icy nightshift the x350 got super stiff plus way too frightening high . I thought it might explode .
Sdd said front and rear left sensors shot.
Went to jaguar dealership and bought 4 new ones 2 front 90€ and 1 rear160€ . All went well i finally realised i could replace the last rear one on the right side too but using a new front sensor and switching the longer arm from the old rear sensor over. 20min with pryer and hairdrier .
perfect improvement in comfort 10 to 15 percent
A couple of days later ordered 3 front ones for the x358 changed the longer rear arms over to the new ones
Installed ,working like it should at first plus a felt 15- 20 percent improvement in comfort( despite 20 inch rims).. after returning from a 20 minute test drive Tom parked the car parallel a wall where the road has a dide incline . So the car stood lower on the right. Next drive same problem is back, transport mode
That was a year ago still did not find the real reason. Car had a crash in the back detected in the boot floor. The connectors on top of the struts might have a problem. One thing for shure it was not the hightsensors
SDD will probably point you in the right direction. Since it is put in firm due to any fault in that system it helps to see which is causing the problem. The early XJ8s are problematic if using some of the clones since they only function on CCF cars and not VID block ones. Not sure if the output can be cycled on and off with SDD to see if each works. Some things can and some not. I have a 2004 built in 2003 and a number of clones would not even talk to the ECU!
I have been having an error where no DTCs are set but when monitoring my I930 signals when driving the PID Damper Firm error =YES. All shocks are firm. Level is fine. Compressor works as it should. I decided to OHM out the switching solenoids on each shock. ( the solenoids that control soft and firm) Testing the front ones a measure 5.4 ohms on both front shock. The rear ones measure 2.4 ohms on both. Is this correct? I thought they should all measure 5.4 ohms.
skywarrior
03-07-2024 01:22 PM
03Xtype
11-27-2014 11:13 AM
