Air suspension issues with Codes C2302 and C1419
I learned from wfooshee that the long term problem with this whole air suspension system is it's inability to remove all the moisture from the air. It was crippled right out of the factory because of this. As time goes on more and more moisture accumulates through out the system. When I took my compressor apart water just poured out.
"In Industry..." drying compressed air is a major bizness, not left to a puny dessicant charge that was optimistically meant to be ignored for life. Oxygen separation plant, we even remove CO2 before starting the harder work.
Improvement is as easy as FIRST running the compressor output through a water separator (not the same animal as a dessicant chamber), only afterwards a dessicant chamber, BUT .. one designed to be serviced easily and often.
Blow-down valve needs to be at the water separator.
Nothing new in any of this. Larger versions had been on each of our five natural gas wells going back to War One.
In more appropriate sizes to this application the goods are dirt-common for shop air, any place as needs reasonably dry air where a "passive" solution is good enough. For the tiny volumes involved here, even "overkill" sizes are neither so bulky nor expensive that a place to live on the motorcar is all that hard to provide.
https://www.ebay.com/itm/152579752055
Bead colour intensity indicates how 'dry' they are, so if a clear packet put by were to get cut while on your shelf, the damage would be obvious .
That said.. as the material is dirt-cheap if bought in larger quantities? Search on "orange silica gel beads", find even Walmart lists it - so we are paying for the convenience of not wasting it easily as much as for it coming pre-measured with the pads!
Other fish to electrocute, so I bought three for my two WABCO's + the rebuild kits I have stashed.
I made the decision to put in a new compressor, since I got a lot of advice that the compressor was probably tired and worn out and leaking, even though I changed the piston ring in my old one already. Nothing improved. My reader says the front dampers are opening when the compressor is on and I have 5.0 volts at each one. The front height sensor starts at -72 and then goes up slowly to -68, while the compressor is on, then drops back to -72 fairly quickly, after the compressor goes off.
If there is a leak, how on earth can you trace it when the hoses are buried inside the floor going back to the trunk.
It is less common for leaks to develop in the air bladders except when a car has repeatedly been driven with the bladders underinflated.
Leaks in the top seal tend to open up more in cooler ambient temperatures, but can sometimes be detected with soapy water carefully spritzed around the top of the air spring (but not in the ECATS connector).
Leaks in the air bladder are difficult to find except by ear, if you can get the air spring to inflate.
Leaks in the air hoses are very uncommon except at the fittings that connect to the air springs.
Leaks are common at the small O-rings that seal the brass pressure-retention valves to the air spring. These can often be heard or detected with soapy water.
To get the fronts to inflate, try clearing all diagnostic trouble codes, preparing your leak detection techniques, run the engine for two minutes to allow the compressor to run its complete cycle, then shut off the engine and listen and use your soapy water.
Air hissing from inside a wheel well is usually a leaking air bladder.
Cheers,
Don
The following 2 users liked this post by Don B:
MountainMan (04-16-2024),
Thermite (04-10-2024)
You may already have an 'open air' mic - close as a cell phone?
Or.. a set of 'contact' microphones - sold for electric guitar repair - is quite cheap on ebay.
Connect to any of many audio goodies that has an audio spectrum analyzer feature as part of its media suite (most laptops and smartphones) - or an Oscilloscope if you happen to have such, and you can put the mic right up close and personal where your ear won't fit, then "see" what you cannot "hear".
Better as well as cheaper than purchasing an ultrasonic leak detector gadget, as used for refirigerants and other compressed gas leak detections.
It is no more possible for a man to have "too many tools", than to get a wife to agree that, but those are optimized for far higher frequencies than we actually need, here. Unless you also DIY your air-con system?
Thanks for the tips.
All my air springs are new, my compressor is new, I have checked all connections with soapy water (top of each air springs, all connections on valve block in trunk). I listen in the trunk, while the compressor cycles off and on and I can hear things actuating in the valve block, cannot hear any air leaking. When I remove the air line connections at the top of each air spring, air is coming out of the hose, when the compressor is running.
The only thing left to have an issue is the valve block or the height sensors.
The height sensors give me readings on my iCarsoft i930 reader and the numbers change slightly up, on the front, while the compressor is on. I assume the sensors are working. Do they control more than the height number?
Is there a way to check the valve block, before I pay $300 +/- for another part that is not causing my problem?
.... I assume the sensors are working. Do they control more than the height number?
Is there a way to check the valve block, before I pay $300 +/- for another part that is not causing my problem? [/color]
Same again, height sensors. Cheap enough. If in doubt, swap it out.
China is Tata / JLR's largest market, so they have had a joint venture factory there for many years, already.
Alliexpress will find the parts we need at the prices the frugal Chinese pay.
About $36 to $58 for a solenoid valve block taste better than $300?
I mean.. it leaves money so one can still afford to go and eat sumthin' else a whole lot tastier, yah?
It still seems to me like you have a leak in one or both front air spring circuits. The most common leak points on new air spring/damper units are at the O-rings for the pressure-retention valves (the small brass cylinders that thread into the top of the air spring and to which the air hose fitting connects), and also at the air hose fittings themselves. If you did not replace the compression rings ("olives") or trim 5 mm off the ends of your air hoses when you installed the Arnott units, you may be losing air around the air hose fittings, although those leaks are usually the easiest to detect with soapy water (when the system is fully pressurized).
Also, you may need to recalibrate the ride height of your car. You will probably need the Jaguar Land Rover SDD system and at least a Mongoose clone cable. Search the forums for instructions on how to set up SDD on a laptop.
P.S. Your car is a factory project code X358. The X308 was the XJ designation from 1997 through 2003.
Cheers,
Don
XJRay (04-16-2024)
#30
#31
I do not feel I have a leak in the front air springs. I have checked with soapy water, numerous times. I had the front of the car bottomed out to start, then I put in two new front air springs, with the exact same result. I do not thing the new air springs have a defective connection. They come with the brand new fittings and when I took off the old fittings on the ends of the old air supply hoses, they were in very good condition and the ends were cut very square.
What Bill said, the iCarsoft I930 can read the pressure sensor and the damper voltage and when they are open and closed.
Thermite (04-14-2024)
#32
XJRay (04-16-2024)
#33
To Don's point in re "sensors". I have enough of an electronics bench to ****-eyes the devices unto boredom. But it makes no sense to bother, given "nothing lasts forever". If Hall effect approaches immortality, surely the plastics do not.
Replacing them on age and gambling-odds alone, cheap as it has become, at least rolls a NEW set of dice.
As to air strut leaks? Wouldn't yah know it.. there is actually a US patent on repair of those?
https://patents.google.com/patent/US20070141253A1/en
No surprise, is it, that as with MOST patents... the technique is "obvious" enough.. but doesn't actually WORK!
#35
I haven't twigged to why they dropped to ONE front sensor and kept two rear, when it would seem bass ackwards, given driver as sole occupant at front... or not. Whilst rear was more likely to be in-balance, left-right, if not also more often empty.
Then again, I was 60 lbs heavier the year I acquired it than I am now, so the tilt is hardly noted..
#37
Sorry for the long delay in posting. This was a very frustrating process, but I finally got things fixed. In recap, I replaced my two front air springs, my compressor and my valve block and none of it helped. As a last resort, started the car and let it run for a while, as the compressor would cycle on and off. The front did not raise. I went back to the valve block and cracked each connection, one by one. Air would start to leak, then I tightened it back up. There was one hose that did not seem to be pressurized and did not leak when I cracked it open. That was the hose to the front left shock. I figured that was where my problem was. I removed the front left wheel and the wheel well lining. I visibly traced the hoses and it turns out that the front right hose routes over to the front left side and both front hose head toward the back of the car on the drivers side. I could not see any obvious issues. Started the car up and let the compressor cycle and I could hear a leak. Turned the car off and then really heard the leak. The front left shock hose was leaking pretty good and it was right where it went through a plastic zip tie connection, that must have been wearing on it for years and finally made a hole in it.
Long story short, I got some 6mm hose and pressure fittings off Amazon and spliced in a few inch long piece and then the car leveled right out.
I spent a whole lot of time and money chasing things that were not the problem. I hesitated with the possible hose leak scenario, because I did not think there was any way to trace a leak in the hoses, if they were buried under the floor board, etc.
Lesson learned, check all possible leak options, before you start spending a lot of money.
Since I had replaced my rear air springs a couple of years ago, the only silver lining is that my air suspension system is basically brand new!
Don B (09-05-2024)
KittyVet
05-31-2020 12:57 PM
