Air suspension system faults
Guest
Posts: n/a
Does the air suspension ECU reset when the ignition is turned off and back on? I know you have to take the Land Rovers to the dealer to have the ECU turned back on when they throw any faults. Was wondering if the Jaguars worked the same way.
Thanks for your help
It stores the fault code, if that's what you are asking about.
The warning itself dissapears from the screen if the cause is no longer present. The code is stored and can be retrieved by the dealer.
I'm not sure what you mean "turn back on" surely the ECU does not stop working, just because of a fault code. The "check engine" light might be on and may have to be reset, but the ECU is working to the best of it's abilities.
Received 2,190 Likes
