Airbag Flash Code 17
Old 02-05-2021 | 04:43 PM
btweatherford's Avatar
Default Airbag Flash Code 17
So mine flashes once, pauses, the flashes 7 times. Error #17. What do you make of that code #?
Old 02-05-2021 | 08:32 PM
motorcarman's Avatar
I don't think the X308 passive restraint systems here in the US uses a flash code.
Are you sure you have the X308 model? (1998-2003)
Might want to start a new thread instead of dragging up one from 4 years ago.
File Type: pdf
Old 02-06-2021 | 11:30 AM
Thanks Motorcarman. My bad in wrong thread posting and no car signature information. As my teachers always said, "read the instructions first....". Still learning.
Old 02-06-2021 | 03:32 PM
vincent661983's Avatar
Check out the air bag clock spring
Old 02-06-2021 | 08:57 PM
Don B's Avatar
Hi Bt,
I have moved your posts to the X350/X358 forum, assuming you are inquiring about your 2008 XJ8L, though I'm still not certain you have made that clear.
Cheers,
Don
Old 02-06-2021 | 10:16 PM
Wingrider's Avatar
+1 on the clock spring
Old 02-07-2021 | 09:53 AM
I doubt the cancellation module (or clockspring) has anything to do with the fault.
Passenger spatial sensing (Occupancy Position)
CAN circuit fault
Flash code 17
Here are some DTC guides.
File Type: pdf
File Type: pdf
Don B (02-07-2021)
Old 02-07-2021 | 10:05 AM
Wingrider's Avatar
Sure that you know more about it than me.
When mine was flashing, one, & seven, it was the clock spring
Old 02-07-2021 | 09:38 PM
I'm just going by the DTC guide.
Passenger spatial sensing (Occupancy Position) is for the passenger side airbag deployment.
I did not read ALL the possibilities related to 'flash-code' 17.
Sometimes a flash code can have multiple faults and the actual NUMBER in the module will be more specific.
Flash codes can be very general as there are dozens of DTCs for the SRS.
Don B (02-08-2021)
etaent
03-14-2019 04:43 PM
fishman
11-21-2017 02:34 PM
cmccutcheon
05-18-2013 03:46 AM
eds123
12-30-2011 03:40 PM
seawind
06-20-2011 12:32 PM
Quick Reply: Airbag Flash Code 17
