Airbagfailure
Hi Alex, the error code relates to the side airbag on the passenger side. Either the airbag unit itself is the problem or the cable/plug wiring to it.
JLR Dealership has a special tool that, attached to the wiring plug, determines whether the side airbag unit is OK. If this is the case, the electrical connection must be checked.
Fritz
Fritz
Fritz
Fritz
The side airbag is located on the outside of the backrest. The saddler probably knows how to get there.
But i would first remove the seat and check the cables and plugs.
The side airbags do not contain an explosive charge but rather compressed gas. Even after the fault has been fixed, it is usually necessary to delete the DTC from the memory in order to get the warning lamp off.
Fritz
Fritz
Tonight i took the seat out and removed the side airbag. Saw nothing strange in the wiring. Cleaned all conections and was planning to order a new side airbag. Put it all back together and mounted the seat back. At my surprise the light went out ! Did not even have to remove fault codes !
thanks for the help !!!
