Airline olive source
ferrule
Panelhead,
Here is a link to my same question.
https://www.jaguarforums.com/forum/x...ection-163575/
The pump line uses the same olive as the line connection. I searched locally but no one had this unique olive (ferrule in the USA) as it is flat on the bottom.Most shops here in the US will only have SAE, Some will have metric but not like the one you need. If you buy this line fitting at a dealer it will come with the ferrule. Part #C2C9930 - 4mm , about $10. The dealership does not have single ferrules for sale.
A tip I've learned about the ferrule...it does not provide the seal...it only holds the line in place. After breaking my second one, I just used a razor blade to snip off the bottom 1/8 or 1/4 of the line. I placed the two halves of the ferrule back in the connection and it holds. Verify with soapy water solution.
John
John
Headed to the dealer once back in Houston.
Panelhead,
A tip I've learned about the ferrule...it does not provide the seal...it only holds the line in place. After breaking my second one, I just used a razor blade to snip off the bottom 1/8 or 1/4 of the line. I placed the two halves of the ferrule back in the yard. connection and it holds. Verify with soapy water solution.
John
John
Found online
Panelhead,
John
John
You will get the nut, o ring and olive. Jaguar only sells as a set. (Meaning parts to service 1 air line fitting)
I purchased mine from SNGBarrett.
They take about 2 weeks to arrive. I personally stocked up and ordered extra ones for down the line.
Your looking at $8 - $10 each I believe.
You have to cut back the airline about 3/8 to 1/2" - do not try to put a new olive back on the same spot on the air line. It will not seal right.
There are actually oem spec shears to ensure a square clean cut to the air line. This is also important if using a blade.
Take your time..
Don B (08-08-2016)
klintous
04-15-2022 10:44 PM
