Alarm Keeps Going Off Randomly!
The car alarm on my X350 keeps going off randomly after I lock the car. I check all the doors and latches to make sure everything is closed and the problem still persists. Sometimes I let the alarm continue until it stops, but then a few seconds later it continues to keep going crazy again! Any ideas on what it could be or how I can fix this annoying problem?
Lilloco423 (06-11-2020)
The following 2 users liked this post by abonano:
Don B (02-15-2015),
JagManBonano (01-29-2015)
The following 3 users liked this post by clifton94:
To echo the above, in 99% of cases it will be the bonnet or hood switch, it is mounted to the underside of the right hand latch if you are standing looking at the engine bay. The best way to determine if the switch is at fault is to simply short it out with a piece of wire on the pins of the connector. If this stops the alarm you can either swap the switch out or keep the shorted connection as I have done.
One point to note is that Jaguar issued a TSB relating to the failure of these switches which is exacerbated by lubricating the bonnet catches. A point to watch out for if you replace the switch.
If you have the Jaguar dealer diagnostics, SDD, there is a facility in it to determine the last alarm activation reasons.
The following 2 users liked this post by SimonXJ:
Don B (02-15-2015),
The following 2 users liked this post by SableCat:
Don B (02-15-2015),
JagManBonano (02-10-2015)
Received 9,011 Likes
Don B (02-15-2015)
baskervillema
10-01-2015 06:43 PM
