Allergic to Car Washes
Interesting problem that I have had twice now. Went through a car wash with a undercarriage spray (won't anymore) and within about 50 feet, the car dies and will not restart, just cranks. Found out after the first time that the ignition coil fuse blows. Has happened twice so I will choose a different car wash. Anyone else have this problem?
Also, it triggers the check engine light and I was curious if there is anyway to reset that without taking to a mechanic?
water in the engine bay wreaks havoc on the electrical system - throttle body, MAF sensor, ABS, etc. not to mention those fuse boxes and relays, the lids can easily have cracked, deteriorated seals, or not closed well and allow steam/moisture in. Don't take the car through automatic car washes.
The light should go out on its own, unless its a misfire or emissions exceedance, or other 'worse' result from your amphibious pursuits.
BrentGardner
28
04-26-2024 03:08 AM
Nati
05-16-2020 08:30 AM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
