Alpine Front Door Speakers.
I just noticed that on my Alpine Sound System the front door speakers produce almost no sound. The dash and tweeter speakers in the front work fine but the most I can get out the doors is a very low muddle. I can not find a chart that tells which speakers is which and can not figure out if this is normal or if something is not working right?
I had the same problem with every one of my door speakers, which is apparently common with all of Alp9ine's DD speakers. Here is how I fixed mine: https://www.jaguarforums.com/forum/x...failure-68885/
Well, they should be getting the same amount of volume and identical bass frequencies as the rear doors; make sure your Front/Rear levels are equal before comparing. If still nothing, or poor sounding, they could be blown/damaged, or like gmcgann's above. Taking one from the rear door and testing it up front will also clear up any doubts.
I get plenty of bass out of the rear doors but almost nothing in the front. The tweeters and dash ones both work fine but on both sides the best I get is a very low whisper. Nothing like the back doors and its weird that's it's both sides. Also I tried the different modes and changed the DSP but nothing seems to change
Take the speaker out and test it. You can use an ohm meter to read the resistance or you can just hook it to your home stereo - unplug the wires from one of your home speakers and touch them to the terminals on the Alpine. If you get no sound, try touching the wires to the actual speaker leads from the connecter to the voice coil. If it works then you have the classic Alpine connector failure and you can fix them the way I fixed mine. Try not to drip any solder on the speaker cone.
One more point about bass response - I've discovered that if you set the DSP to "all" the bass is greatly diminished. I've heard this was for rear seat passenger comfort. If you set the DSP to front you'll get all the bass from your Snoop Dog CD.
PigletJohn (07-14-2013)
Alright I had my speakers tested today and they work great. My local shop hooked them up to different sources and they all worked fine. The problem is the car is only sending a very low amount of sound to the front door speakers. We tried different ones and car did the same thing? Has anyone else had an issue with there alpine amps doing this?
