Alternator extraction on a '03 XJ8 / X350
In order to extract the alternator from the car, after dismounting it, do I have the choice of removing the right side engine mount or removing the radiator fan assembly? If the radiator assembly is viable, how much has to come out? If both approaches are viable, is there a clear winner? The last question my be influenced by the fact my car has seen 7 New England winters.
Alternator, belt, tensioner, idler pully bearing, starter, radiator, thermostat, with housing, both water pumps, & hoses.
All removed, then replaced would be a good way, with some room to work, & get a lot done.
The other way, using a lift, is how i did both of mine,
Did the starter & alternator, at the same time while i was there
Everything has to be accessed from the bottom. Lift is best of course but 18 inches on stands is how i did my 06 str with the passenger tire off. The 4.2 is the same for both. Even the wheel liner off or pulled back. The alt plug is tricky. I took mine alt loose and then the plug was easy with more working room
I should have finished this thread earlier. My starting, alternator and starter motor issues were all do to a poor engine ground. Most cars have the battery in the engine compartment and the battery ground goes directly to the engine, by far the largest amperage draw (the starter). With the battery in the trunk and the ground strap to the unibody, the strap from the engine to the body is responsible for engine sensor grounding, alternator output delivery and starter grounding. The poor engine ground resulted in low voltages at sensors (causing engine running issues), frying the alternator and replacement of a good starter. It's been 6 months since I cleaned the ground strap and everything is fine. Aluminum can show little corrosion with little electrical continuity. If there had been no electrical continuity, the problem would have been easy to find. Use dielectric grease on all aluminum connections.
raywilcauskas
07-07-2016 08:45 PM
bookman
11-10-2014 10:17 AM
Paratrooper54
03-13-2014 07:36 PM
jimlombardi
10-21-2013 03:44 PM
