Angle of sideview mirror creeps up
Old 08-29-2022 | 03:42 PM
nhammers's Avatar
Default Angle of sideview mirror creeps up
My passenger side mirror on my 2005 Vanden Plas correctly dips when I put the car in reverse. Yet the mirror doesn't return to the same fixed position to which it is set when I put the car in drive. Over the course of several cycles of reverse-drive-reverse-drive, etc., the mirror tilt gradually gets higher, until I have to reset it manually or by pushing the memory button. Any ideas for a fix? Thanks.
Old 08-30-2022 | 10:06 AM
Tigre's Avatar
My '04 XJR does the same thing . Other than bumping it back down occasionally, I'm not sure of a fix. I suspect they need to be disassembled and cleaned/ lubed.
Old 08-31-2022 | 12:34 PM
abonano's Avatar
My 04 does the same. The actual mirror motor (w/ memory function) needs to be swapped out. Actually if you have SDD you'll find a code...
I choose to live with it for now.
Tigre (08-31-2022)
Sprinkler
05-19-2020 07:57 PM
Jagjustin
04-01-2015 08:28 PM
pearlfisher
02-25-2013 11:15 AM
davies
05-19-2011 10:06 AM
LarryK
03-24-2008 10:39 PM
Quick Reply: Angle of sideview mirror creeps up
