Another Front End Rattle Thread
#41
Received 12,946 Likes
AIR SUSPENSION FAULT UPDATE: The night before last, I decided to conduct leak tests on my compressor hoses and the valve block hoses. No leaks. However, for the heck of it, I unplugged the two electrical connections on the valve block and inspected them. They seemed clean, so I plugged them back in. Three drive cycles of at least 17 miles each have passed since then with no sign of the ASF message, whereas before it would appear after 10 mins every single time no matter what. I'm hesitant to claim victory, but its an encouraging development to say the least.
That sounds encouraging, XJ8JR. If the ASF does eventually return, perhaps it would be worth flushing the valve block connectors with zero residue electrical contact cleaner spray to see if that effects a more permanent solution. Please keep us informed! I for one am very encouraged!
Cheers,
Don
#42
#44
#45
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Lagonia (01-15-2016)
#46
Try disconnecting the upper ball joint again and see if you have any play in it while trying to move the ball joint up and down in its seat. Hold the top of the control arm in one hand and the threaded end of ball joint in the other and push up and down hard and see if there is play in it. If so it is shot. This was bad on my car and replaced them with cheap ebay control arms which lasted a wopping 3 months and noises came back. Moral of story don't buy the cheap ones. Also, you could have a second person tap with a hammer lightly on the control arm end while you are in the car and see if the noise is the same or similar. My bet is the ball joints in the control arms are shot and or the sway bar end links but you are already going to replace those.
#47
#48
Dunno if $358 is considered cheap for the pair. I will find out! I will be replacing these this weekend and will document and report in a separate thread.
#49
I have already purchased the control arms from eBay. This is where I went to: Jaguar XJ8 XJR Upper Control Arm Arms Ball Joint Bushing C2C38956 C2C38957 L R | eBay
#51
