Another surge problem
I am fairly sure this one hasn't been covered before or at least I can't find anything on it.
A couple of weeks ago I did what has turned out to be something stupid, I took the car through some deep(ish) water, now it wasn't crazy deep maybe 4 or 5 inches I think but since going through the car has decided to start surging. somewhere around 1500 to 2000 rpm, it's quite pronounced and makes the Jag pretty uncomfortable to drive, there are no fault codes showing although the fuel trim levels seem to vary a lot between banks. I'm not familiar with what the fuel trims are but I would assume that the readings should be similar between banks.
Question is, What could have been disturbed by the water to cause this? it may be a coincidance but I think it unlikely. the engine pulls just fine and you can drive through the surging but I would be grateful of any suggestions I can try. !
Richardhw (10-19-2020)
Cerberus66
05-08-2012 11:39 AM
