another transmission fault thread
Old 05-11-2018 | 04:48 PM
metalmarty's Avatar
Default another transmission fault thread
Hi all, 2005 XJR here.
I got a transmission fault that seems to be causing the car to only operate in two gears, maybe 3rd and 4th? I am sort of guessing this judging by 3k rpm at 65mph. I did have some issues about a year ago which I resolved by replacing the pan and refilling the trans with mercon sp, but it has ran well since then. It also whines sometimes when I accelerate too hard, like if I'm on a hill and have to rev it up to get it moving because it's starting in a higher gear.
Anyone ever have this issue or know what can cause it? Being as temperamental as Jaguar's can be I don't want to automatically assume the trans is just bad because things like a slightly low battery can completely destroy every system in the car, etc.
Oh, and I did have the surging rpm issue on cold mornings in the past, if that offers any insight into the issue.
Old 05-11-2018 | 06:08 PM
meirion1's Avatar
Any fault messages on the dash?
Have you had any ATF leaks?
Check the level of fluid in the Transmission.
Scan for codes.
The surging RPM when cold is 'normal'.
Old 05-11-2018 | 06:24 PM
pkoko's Avatar
How many miles?
Old 05-12-2018 | 08:25 AM
metalmarty's Avatar
Originally Posted by pkoko
How many miles?
about 145k, I changed the pan and fluid around 135k i think, it was last year
Old 05-12-2018 | 08:27 AM
metalmarty's Avatar
Scan for codes.
The only message is transmission fault. It was leaking at one point before the pan change and I did top it off once after. I will have to recheck levels.
Old 05-12-2018 | 03:46 PM
pkoko's Avatar
Why are you losing fluid? Maybe the cooler lines are leaking....
KenAdamson
135
01-04-2019 10:43 AM
XJ8JR
44
08-13-2016 01:29 PM
Beep777
09-15-2012 09:36 AM
Quick Reply: another transmission fault thread
