Another weird parking sensor problem
The scenario is a little different. Two of the four parking sensors are working. This will be the rear of the car. The inboard 2 work fine, the outboard 2 do not work at all. I had the bumper off.
All the wiring is good and I'm getting a strong clicking from the outboard sensors when in reverse but no warning beep... Thanks
I did replace sounder. It is behind rear glass under parcel shelf on passanger side.
You will have to pull out rear seat, back of rear seat and parcel shelf to get to it.
replacement:
I can't find in my records where I got it, It used on many different models Ford and Mazda among others:
https://www.walmart.com/ip/Car-Park-...866A/803673576
https://www.aliexpress.com/i/3256806...apt=4itemAdapt
replacement:
But they are not working are they?
This is what I have done
Remove rear bumper and carefully pull out all sensors
with wiring intact
Place wiring on top of thick metal bumper with sensors
pointing in the right direction.
test with your hand in front of each sensor to see which ones are not working
Remove any non working sensor and replace with a good one until they all work
NB ignition in pos 2 and g'box in reverse
with wiring intact
with wiring intact
with wiring intact
Jagfrenchie
06-06-2015 01:22 PM
Bkny85
02-19-2014 09:43 PM
