Antenna damage.
Old 08-22-2023, 12:58 PM
eggdoc41's Avatar
Default Antenna damage.
I mistakenly started this thread on wrong forum. Briefly, Broken mast and damaged antenna cable in trunk. I've removed backseats and have achieved enough cable length to attempt repair. Hopefully I can complete that and move on to broken mast issue. Then I'll return ... Again, sorry for screw up.
Old 08-22-2023, 02:44 PM
eggdoc41's Avatar
Any suggestions on how to complete this splice?
Old 08-22-2023, 03:34 PM
Big Koshka's Avatar
Cut and replace:
Amazon Amazon
Old 08-24-2023, 10:06 AM
eggdoc41's Avatar
"Cut and replace" done. Any tips/hints re: taillight removal and access to mast/motor?
Old 08-24-2023, 10:10 AM
eggdoc41's Avatar
Cable repaired. Any tips/hints re: taillight removal and access to motor/mast?
Big Koshka (08-24-2023)
Old 08-24-2023, 02:04 PM
eggdoc41's Avatar
I've exposed tail light compartment and motor/relay in trunk. Looks like local mechanic did rather shoddy job of replacing antenna. Now I'm uncertain how to precede.
1. How to release antenna from chrome fitting on top of fender?
2. Do I need to remove motor and if so how?
When I turn radio on motor hums then several harsh clicks. Same sounds when I turn radio off. I assume motor is ok? Appreciate any help.
Old 08-24-2023, 02:15 PM
Big Koshka's Avatar
Old 08-25-2023, 09:24 AM
eggdoc41's Avatar
Unfortunately, the video noted relates to a series 300 I believe. My XJ6 III Has a motor remotely mounted. Do I need to remove motor and if so, how? I'll have many questions as I progress, but I'm trying to go one step at a time
Old 08-25-2023, 03:49 PM
eggdoc41's Avatar
I also am having trouble pulling broken antenna out of enclosing tube...It feels like I'm hitting a audible "stop" when I give it a jerk. What's that?
Old 08-26-2023, 06:36 AM
Big Koshka's Avatar
Hey, Doc,
I am not sure if this will help or not. I never worked on car similar to yours. With this said, I did searche for some information:
https://www.retromanufacturing.com/p...NVqt7619vQJUh0
As it said it is not an OEM solution, but rather 'aftermarket'
You're still posting in wrong place, doc!
You should post your question here:
https://www.jaguarforums.com/forum/x...s-i-ii-iii-16/
eggdoc41
08-20-2023 08:40 PM
leoholland
11-08-2022 04:50 PM
Canadacat
08-05-2021 12:17 PM
DavidN
05-26-2021 12:49 PM
Fozberry
03-24-2012 10:07 AM
Quick Reply: Antenna damage.
