Antifreeze OEM Pentosin
Hello guys, Happy Easter 🐣
What is the Antifreeze OEM to use for my 2004 XJ8?
i don’t want to go to the dealer , is Pentosin ok?
i heard that it has to be pink , is it true?
i see Pentosin frost at Advance Auto Parts But I don’t
know if that is the OEM but is definitely pink
Peak makes one called European formula ...it is oat based....on the jug it says the make of vehicle and spec it meets....it covers the jaguar spec and is pink....it is a 50/50 mix....no need to dilute...i use it with no issues....just make sure the brand meets the jaguar spec....do not use anything glycol based....the jaguar spec is in the owner's manual for sure and maybe on the tank...i got mine at AutoZone...pentosin is good too....just make sure it specs
Don B (04-22-2019)
The following 3 users liked this post by motorcarman:
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Thanks for the info
the pentosin at the advanced autopart store it is not 50/50 , I ill look for that peak coolant
The following 2 users liked this post by Partick the Cat:
Don B (05-12-2019),
motorcarman (04-22-2019)
Received 13,203 Likes
As far as I know, the most commonly-available OAT (Organic Acid Technology) XLC (Extended-Life Coolant) that meets Ford specification WSS M97B44-D is Prestone Dex-Cool, which is available at Walmart and most auto parts stores. It is colored orange just like the official Jaguar XLC (though color is not the best determinant of the correct coolant - chemistry is what matters).
Pentosin states that Pentofrost SF (colored pink) meets Ford WSS M97B44-D, but it is most commonly sold in 1.5 liter bottles and is significantly more expensive than Dex-Cool.
The best deal I know of is to buy a gallon of concentrated Dex-Cool from Walmart and mix it with a gallon of distilled water from the grocery store.
Cheers,
Don
Cheers,
Don
The following 3 users liked this post by Don B:
Cheers,
Don
Cheers,
Don
antifreeze for Jaguars 1997 on . Also Advanced Auto parts has the Pentofrost SF for Jaguars 1997 on .
the dealer has the Pentosin, Pentofrost SF as part number JLM 20972 . I asked them for the part number and matches the Pentofrost SF OEM reference number
find pics attached
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/d383a64b_5399_4dc5_bfb3_07e0e4eae130_ed7f4272df5faad538530d62bb2f4e487e20d76b.jpeg)
At Autozone for $19.99
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/edc25cc2_fca8_4e6f_bcbf_2aa8ce1d89b6_9ab45b883a70e80f0800d370ab2d53b8fb1212e3.jpeg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/244e5ca3_aa08_42a5_b9ad_4df41aeaa3fb_00ed1066f2b5e2f5f88d5d90346cd8eecd3dbde9.jpeg)
Pentosin pentofrost SF at Advance Autoparts $14.99
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/277676ec_5e90_49f4_8eff_a7d77177ba59_c33f2384402663eb98f6a841525a0183bffdbe9b.jpeg)
Highlighted information
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1515/6bbe5155_3192_40dd_8105_413609478bd0_29d903079f7087e9dd020736949016aa9b7d4f0f.jpeg)
well I just found out that Autozone has the Peak pink
find pics attached[/QUOTE]
Don B (05-01-2019)
You can compare the chemistry of other coolants to that of genuine Ford Motorcraft Orange OAT coolant, Texaco Havoline Dex-Cool, and Prestone Dex-Cool, all of which meet Ford specification WSS-M97B44-D. You can download the Material Safety Data Sheets at these links:
Ford Motorcraft Orange OAT Coolant MSDS
Texaco Havoline Dex-Cool MSDS
Prestone Dex-Cool MSDS
All three coolants are predominately Ethylene Glycol (CAS 107-21-1) and Diethylene Glycol (111-46-6), with slightly different organic corrosion-inhibiting additives disclosed in their data sheets (additives that are not toxic may not be disclosed on the data sheets):
Motorcraft Orange disclosed additives: Decanedioic acid (111-20-6) and tolyltriazol (29385-43-1)
Texaco Havoline Dex-Cool disclosed additive: Potassium 2-ethylhexanoate (3164-85-0)
Prestone Dex-Cool disclosed additives: Hexanoic acid, 2-ethyl, sodium salt (19766-89-3) and Neodecanoic acid, sodium salt (31548-27-3)
Cheers,
Don
Cheers,
Don
The following 2 users liked this post by Don B:
MountainMan (05-03-2019),
scottjh9 (05-01-2019)
