Is anyone interested in a chip tuning using SDD?
Old 10-31-2014, 04:31 AM
MoscowLeaper's Avatar
Default Is anyone interested in a chip tuning using SDD?
Ok, i've finally cracked a firmware tables/date and vbf file format, so now i'm able to make a SDD flashable tunes.
It is possible to tweak almost any parametr in a f/w, including
-gear ratios (incl. rear end ratio) - not tested yet, since i don't have a 3.0 diff)
-speed limiter can be tweaked to any speed
-ignition and fuel maps (tested, runs awesome, especially if water/meth is installed)
-revert a f/w to any emission standart
-disable any DTC and perfomance restricions
-A/C cut-off speed and rpm
-fuel cut-off rpm
many other things, the complete list may take a few screens, but i can send it in a .csv file.
So, is anyone intrested?
P.S. tables/data are available for aj-27/later V8 engines, 3.0V6, 2.7&3.0TDV6
The following 13 users liked this post by MoscowLeaper:
avos (11-02-2014), Cambo (10-31-2014), ccfulton (11-01-2014), doc (10-31-2014), Don B (01-18-2015), ednedwards (11-17-2014), hafren (10-31-2014), JagDaniel (03-20-2015), JgaXkr (11-02-2014), Lady Hirsel (11-21-2014), lcmjaguar (10-31-2014), LuvmyJagNZ (10-08-2019), Panthro (06-01-2016) and 8 others liked this post. (Show less...)
Old 10-31-2014, 04:34 AM
ragman1171's Avatar
I'm definitely curious...
Old 10-31-2014, 04:44 AM
Ok, i need your stock calibration ID and your wishlist
Old 10-31-2014, 04:56 AM
Received 4,457 Likes on 2,427 Posts
YOU HAVE MY ATTENTION!!!!!!
Yes, yes and yes!
Old 10-31-2014, 04:57 AM
Yes, yes and yes!
Calibration ID and wishlist
P.S. Now i'm in research to have two tunes - for water/meth and stock. For water/meth i can lean a mixture and advance a spark in a main map, now i have an idea to use a spare table (used i.e. in a case of restricted perfomance) to provide a stock mixture/advance. If everything will go the desired route i'll be able to switch tunes by, i.e. interrupting one single wire with a switch.
Old 10-31-2014, 05:03 AM
Diff ratio to 3.58:1
Faster transmission shifts
Remove torque limitations in ECU
Tweak fuel maps
AJ33S in 2005MY XJR, vin G35785
What other information do you need?
Old 10-31-2014, 05:07 AM
Tweak fuel maps
1. Possible, but not guarranteed. As i can see a TCM gets the ratio info from a ECM, but i'm not pretty sure if it will work. Anyway, i'll make two files, one with stock ratios, second with modified
2. For that it'll be needed to redice torque decrease demands, it may give some "hard" shifts
3. 1024Nm limitation would be fine, i guess?
4. Water/meth? octane? Should a spark advance remain stock? Desired AFR for a coast/idle/WOT condition?
5. Vin is enough, i'll check a cal-id in a SDD database.
Old 10-31-2014, 05:18 AM
Ok the stock calibration files are:
z65y5656x350row.phx & z65y5656x350row_data64k.dhx for TCM
n19_s42pm.bin for the ECU
1. I have a 3.58:1 ring & pinion here and a spare diff assembly, but I don't have the 3.0L's 3.31:1 so i'm kind of stuck with that ratio. Easy way to test the file is load it & drive with the "wrong" ratio, if it worked then it'll throw up codes P0720, P0730 & P0780 simultaneously.
2. I think tuning the shifts will need a number of attempts to get it "right" so this might be prio #2
3. The goal here is that the ECU does not "hold back" power unneccessarily, obviously during shifts it needs to reduce torque, but not while in gear at WOT
4. Not interested in water/meth for the time being, just to lean out the target AFR a little. This might also need a few attempts to get right.
Old 10-31-2014, 05:29 AM
Ok, you have a ROW car, so the tune will be 6W93-14C576-BBH.vbf, just like mine is.
1. It throws a codes (i've already tested it), but i'm still not pretty sure if everything will work fine. At least it may require some debugging.
2. Mine shift a little harder now, but that's fine
3. There's a limiter, which limits a maximum torque from an engine, and there's a torque reduction threshold for shifting torque reduction. I can change both of them to a higher limits.
4. Not a problem. I thing it will be better to leave coast/idle AFR as a stock (14.6:1) and to lean a power enrichment target AFR somewhere between a 12 to 13 (but it may cause a detonation in a hot weather or if there's a poor quality fuel). I'm running a 13.5 with a water/meth, no pinging (but, again, it's almost winter over here).
Old 10-31-2014, 05:49 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
Interested, yes - is there a URL or some such?
Old 10-31-2014, 06:05 AM
ragman1171's Avatar
I would venture to say that I have a very similar setup as Cambo, but I don't know what I have or where I want it to go as I've not had Anya long enough to know where to go. I don't know where to look to get the info you're requesting yet, but I want to learn. My VIN code is: G40095. 2005 XJR with 108,000 miles on her. THANK YOU!!!
Rags
Old 10-31-2014, 06:26 AM
This all sounds good.
Any chance you can fix the temperature gauge so it gives a real indication?
Nope, no URL yet, the most part of the R&D were completed yesterday, so i had no time to make any documents about it. But they'll be on my site, since, in a future, i have a plans to sell the custom-built f/w for a decent price (not as much as eurotoys or other companies)
Feel free to ask a questions.
For now i have to edit a binaries with a hex editor, manually correct a checksums and so on, but during weekend i hope to write a handy s/w to make this job easier (like a tool to compiler/decompiler/crc calc of vbf files).
Old 10-31-2014, 06:28 AM
Rags
So, i guess some kind of conservative-enough setup will be fine?
Old 10-31-2014, 06:29 AM
Not for now. The gauge is driven by an IPC, ECM always sends a correct temp.data. So to fix a gauge someone should mess with a disassembler and IPC f/w.
Old 10-31-2014, 06:57 AM
mhamilton's Avatar
Does anything in the PCM show what parameters it uses to run the fans aside from temperature? The dealer flashed my PCM with some update and it has it running the fan for 3 minutes after shutdown in hot weather, but it's not based on coolant temp. Seems like it's based on the fuel temperature.
Old 10-31-2014, 07:03 AM
A coplete list of a parameters is availabe at flash - XJ's and XJR's (all bodies)
Old 10-31-2014, 07:06 AM
Coolant temp, oil temp, transmission oil temp, fuel temp, engine bay guard mode.
Also there's a forced OFF period.
Old 10-31-2014, 08:23 AM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
Think I'll sit in on this thread
Old 10-31-2014, 09:48 AM
Took a quick glance in an IPC f/w. Can't find any visible map of temp vs needle driver. It is still possible to find it by trials and errors, but i'll need to find a spare IPC, since i'm using an XJR as an every-day car and i don't want to brick it
Quick Reply: Is anyone interested in a chip tuning using SDD?
