Anyone know how to remove the shift knob
Old 07-29-2011, 07:58 AM
jahummer's Avatar
Received 2,367 Likes on 1,482 Posts
Originally Posted by 45Wheelgun
You didn't need to use the tape. If you manipulate the silver nut below the knob, you can raise it up and then tighten the knob down. Play with it a bit and you will get it perfect and tight. I got mine at the end of last week and was able to get it lined up perfect and tight using the above method.
That is the correct way.
Important note: DO NOT tighten the knob all of the way as the post will put pressure behind the emblem and over time, the emblem push up through the urethane coating.
Anyhow, looks great! Told you guys he does good work
Old 07-29-2011, 09:14 AM
amcdonal86's Avatar
Is this guy on eBay? I see similar knobs on eBay.
Old 07-29-2011, 10:10 AM
jahummer's Avatar
Could be. Out of Orlando. I sent you his info a couple of weeks ago.
Old 07-30-2011, 02:54 AM
Cadillac's Avatar
Hey, they are also one of our members because I saw their cars in the gallery
Old 07-30-2011, 03:58 PM
Jsedita74's Avatar
yes he does .... but if you call him directly (his name is Saul) he will work out a deal w you... Very nice fella honestly...
Old 10-06-2015, 09:53 PM
Jimstaton's Avatar
I know this is an old thread but I am new. I have an 07 xj8. The knob will turn very tightly but appears to be attached to the chrome plinth. I don't appear to have an appropriately sized Allen wrench to remove the three screws I assume are in the three holes that are in the plinth or guide nut. Does anyone remember a similar situation? Obviously I have to hit the hardware store tomorrow for the wrenches.
Old 10-06-2015, 11:56 PM
Received 12,932 Likes on 6,463 Posts
Hi Jim,
There are no screws in those holes - they are apparently for some special 3-prong tool that Jaguar uses to hold the cone nut while the knob is tightened against it. With enough force, you may be able to turn both the knob and cone nut off the gear shift lever, but if not, try holding the cone nut with Vise Grip/Mole Grip pliers padded with something like an old leather belt to protect the cone nut from damage.
I replaced our XJR knob with a burled walnut knob and had to modify the cone nut. I don't know if the photos at the link below will be at all helpful, but in case they may help you see how things go together, here they are:
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
  #28
Old 02-22-2017, 10:58 AM
Sorry to resurrect this old thread, but trying to confirm how to remove the cone nut from an x350? Does the cone nut just twist off with enough brute force or is there some type of adjustment screw I'm not seeing?
Old 02-24-2017, 12:45 PM
Hi Mike,
The cone nut serves as a "jam nut" against the knob, so don't try to twist them off together. Hold the cone nut as stationary as you can while twisting the knob off counter-clockwise, then twist the cone nut off.
Cheers,
Don
The following 2 users liked this post by Don B:
AD2014 (02-26-2017), EssOess (03-03-2017)
  #30
Old 02-24-2017, 01:58 PM
michaelodonnell123's Avatar
Saul at British Autowood | Dashboard and Woodwork Restoration made this knob for me. Stunning piece of craftsmanship.
Attached Thumbnails Anyone know how to remove the shift knob-143095d1487743455-bought-new-watch-jaguar-padi.jpg
Don B (02-24-2017)
silkcat
04-15-2023 04:58 PM
Jandreu
06-30-2022 03:10 PM
aholbro1
08-05-2021 05:02 AM
1LowCat
02-23-2016 07:19 AM
1LowCat
09-14-2015 07:51 PM
Quick Reply: Anyone know how to remove the shift knob
