Anyone know the proper procedure of removing fog lamps?
Yes. You can either remove the bumper, or you need to come up with a way to remove those little plastic pieces that cover the lower grille (immediately adjacent to the fog lamps). These pieces have little tabs on them that must be sort of bent down before it will come out. You may have to remove the bumper to access them.
After that, the fog lights just have a couple of those torx screws holding them in. The photo below should give you an idea of how they are fastened in there:
![](https://lh5.googleusercontent.com/-7bndZ6AmQvM/TeWUoAYf1dI/AAAAAAAAAL8/Jt34LNnmsAs/s800/2011-05-31_21-21-13_875.jpg)
I think the end of the wheel wrench is plastic coated to you can insert it between the bumper and the top of the plastic cover and lever it out otherwise a flat screwdriver covered with something like a rag for protection should work.
aholbro1
08-05-2021 05:02 AM
rsa760041
23
09-25-2015 01:33 PM
