anyone know the subwoofer specs for the alpine car?
Old 06-05-2011, 04:45 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
Originally Posted by Jsedita74
Jade- yes I also have that "R" button on my screen and it is inaccessible to me. I can not click it or do anything with it. Would anyone happen to know what that is exactly?
From the owners manual:
This feature will allow the front occupants to turn on the rear speakers if the rear occupants have turned them off using the rear multimedia system.
The front user can turn the rear speakers on by pressing the rear speakers on button. If the button is disabled, then the rear speakers are already on.
jadedragon1800 (06-08-2011)
  #62
Old 06-08-2011, 02:30 PM
jadedragon1800's Avatar
that makes sense, u102768, as my rears are working. so now i have to figure why i hear NO discernible sub volume increase or decrease when i fiddle with the sub volume. DSP is on for all areas (front, middle, rear). i'm assuming the subs are in the panell right in the middle of the rear parcel shelf. i'll check. BTW, is there a seprate fuse that feeds the alpine amp? or is it all on one circuit with the rest of the nav/stereo? TIA, wm
  #63
Old 06-08-2011, 04:29 PM
u102768's Avatar
You might not notice much of a difference but the sub impact is intentionally reduced when you have the DSP on for all areas, for 'rear passenger comfort'.
If you switch DSP to driver or front it should, in theory, boost the base.
I find that there isn't a huge amount of base when listening to FM radio unless I turn the volume up above 15 but CD's sound great.
The following 2 users liked this post by u102768:
jadedragon1800 (06-10-2011), Jsedita74 (06-09-2011)
  #64
Old 06-08-2011, 10:57 PM
Drew's Avatar
If you do a search on Kicker subs from 12/09 you will all find a quick write up with pictures on installing the subs and an external amp. The biggest difference I found was removing the trunk liner to allow any sub in a free air design to move properly. The liner doesn't allow subs to hit the lows. I ended up cutting a hole in the liner around the subs and it helped a little.
  #65
Old 06-09-2011, 06:25 AM
Greenhornet's Avatar
Default Dsp
I think this is accurate for all systems in all cars, I've noticed this difference in my Mustang when I turn it from "Driver" to "ALL SEATS".
  #66
Old 06-10-2011, 02:00 PM
thanks u102768 & greenhrnet....tried it and with sub volume turned up all way, can definitely tell difference in bass response. then i turned it back to "all" on the DSP, and bass went into background and wasn't discrenible at all. soooo, if i want to have bass on a good CD track, i just place DSP on front only.
drew, cutting the trunk liner isn't something i would feel comfortable doing, unless it would make a significant difference, and then i would have to find some sort of molding or trim to make it look OEM...maybe with a mesh screen? did you do it with the stock subs or aftermarket subs?
  #67
Old 06-13-2011, 06:30 AM
Default Dsp
Glad you noticed and it made a difference. That Liner thing you mentioned, I can't comment about, cause I have no idea what that talk is about, maybe my X-Type did not have that, but I agree with you on what you are saying about not doing something cause it does not feel comfortable.
  #68
Old 06-14-2011, 03:33 AM
Jsedita74's Avatar
In no way shape or form would I cut or modify anything. The goal is to have it as stock as possible but with subtle upgrades ... Just my honest opinion ....
  #69
Old 06-14-2011, 08:57 AM
Drew's Avatar
I installed Kicker 6.5 subs in the stock location and hid the amp where the DVD player should be. I don't like systems that stick out. My car looks completely stock. I didn't cut into the trunk liner until I installed the new subs an amp, so i don't know if it would help the stock system. The only way you can see the hole is to climb inside the trunk. I thought a long time before I started the project. I too prefer a stock look.
  #70
Old 06-14-2011, 09:56 AM
Default Subs
How does it sound?? Did you snap any pics? I know it's not an easy pic to take, but if you did, show us.
  #71
Old 06-15-2011, 12:06 AM
Drew's Avatar
Do a search for kicker subs on 12/09 The lower tones are better, but doesn't shake your teeth.
  #72
Old 06-15-2011, 06:55 AM
Default Kicker
Not needed, I just wanted to see your setup. I used the kicker 6.5 in my stock Sub setup, and added an additional Sub in the Trunk also. Just wanted to see yours.
  #73
Old 07-09-2011, 03:10 PM
Mkicenski's Avatar
Default Sub-woofer, XJ8
Hello again, mates:
My 2001 XJ8/VP has just one sub-woof enclosure on the package shelf in the rear of the car. The system is an Alpine Premium and the speaker has two (2) sets of terminals, I assume, for left and right. Anyone have similar set-up and where can I go to order a replacement. My meter tells me that both sets of cables are carrying 2.4-5 OHMs. Anyone got any ideas? Thanks
mkicenski
'01 XJ8 Vanden Plas sedan
  #74
Old 07-11-2011, 06:21 AM
Default Sub
It sounds like a Dual Voice coil setup, are both sides hooked up? If it's a DVC then all you need to replace it with is a DVC speaker.
Originally Posted by Mkicenski
Hello again, mates:
mkicenski
  #75
Old 07-11-2011, 06:53 PM
hlgeorge's Avatar
You can probably find the DVC sub woofer you are looking for:
Parts Express
  #76
Old 09-21-2011, 09:15 PM
Docuzzie's Avatar
Greetings all. I require a little assistance also as I'm not a car stereo/Jaguar specialist. Some months ago, I purchased a Bazooka Tube and I just got some time on my hands for weekends so I decided to put it in. It's now mounted, the ground is connected, the 12v connection to the battery is made and the harness is on. I've tapped the wires from the existing subs in the shelf and have unsoldered the leads on them. I have one delimna now and I'm not clear on it.
I need to identify an additional 12 Lead where either the radio draws it's power or an aux 12 source in the fusebox that comes on with the ignition key is turned. Can someone direct me on how I might accomplish this? I have the electrical schematics for the vehicle thanks to Jason Aka PHD12volt, but I'm clueless still of where this connection will need to go.
What would help me most is a picture of the fuse box and where I can connect the remote on wire to either the Radio On, or the 12v Aux connector inside the fuse box.
  #77
Old 09-24-2011, 04:02 PM
ddsski's Avatar
Helps to know what model you are talking about.
  #78
Old 10-06-2011, 11:29 AM
Docuzzie's Avatar
Not to worry, I've worked it out. Fuse 27 in Box B in the Passenger Cabin, beneath the glove Box embedded in the wall is for the Radio. I simply snaked a wire from there beneath the interior of the car to the rear, into the trunk to supply the voltage for Sub On and Off via the Ignition Key being in the proper position.
If you were unaware, my car is a 2005 Platinum STR and the sub woofer I was referencing is a bazooka BT250D 250 Watts of power.
  #79
Old 11-01-2011, 05:13 AM
Received 4,457 Likes on 2,427 Posts
Yes, stay with the 4 ohm, that won't blow the stock AMP, something lower may damage the stock Amp.
Originally Posted by phd12volt
my alpine subs were 2 ohm coils
scroll down on my link, and you can see the alpine part numbers and the measurement of the factory speakers
http://www.cardomain.com/ride/335898...-s-type/page-3
OK, I never saw anything on mine or in my car that indicated that they were 2ohm, and who would figure that a car manufactorer would use 2ohm loads in their Auto's, so no, I never would have tried 2ohm loads on that factory Amp.
Had me worried there for a minute, since I just bought a pair of Kicker CVT65's, 4Ω units.
Jason, in your post on the other site, you measured 2.5Ω on the stock subs...this didn't seem "right" so I had a look around and found this;
To measure the true impedance of a speaker or cabinet requires a rather complex procedure involving signal generators, power amplifiers and high frequency AC voltmeters. However, with raw speakers and many cabinets, the ohmmeter function of a digital multimeter can help you identify what the impedance of the speaker should be. Generally, the reading given by an ohmmeter will be about 2/3 to 3/4 of the impedance of the speaker. So, a 4 ohm speaker will typically measure about 2.5 - 3 ohms, and an 8 ohm speaker will typically read about 5-6 ohms, while a 16 ohm speaker will measure around 12 ohms.
From this site Speaker Impedance Explained - Ohms
fast40driver
04-19-2024 07:24 AM
detXJ
05-22-2016 10:50 PM
innzane
08-26-2015 08:41 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
divingmom
08-25-2015 07:54 PM
Quick Reply: anyone know the subwoofer specs for the alpine car?
