Anyone noticed smoother downshifts into 1st in sport mode?
Old 08-10-2015, 11:06 PM
Broken_Spanners's Avatar
Default Anyone noticed smoother downshifts into 1st in sport mode?
I forgot to hit the magic button that mostly forgets about six gear, chews up petrol and makes you feel better during stop-light grand prix's ;-) while on the way to work today, and noticed that the ensuing downshifts into first during stop and go speeds were almost seamless as opposed to non-sport mode.
Got me thinking. I assume the pressure changes along with ECU commands to maintain a gear for longer and staying (mostly) out of overdrive, but could this be a larger sign of improper pressures throughout our trans?
My downshifts aren't generally memorable, but I wouldn't call them new car smooth either. Our ZF fitted LR3 experiences this same issue (hard 1st gear downshifts), but has been that way since day one.
Thoughts??
Jeff
Old 08-11-2015, 12:07 AM
dsetter's Avatar
In non sport mode, I understand that there is no change to 1st gear.
Old 08-11-2015, 07:12 AM
There is a downshift into 1st in both modes at very slow speeds / I'm referring to less than 10 mph downshifts, not kickdown.
Jeff
Old 08-13-2015, 07:52 AM
carelm's Avatar
What I've noticed is that shifts are smoother in both upshifts and downshifts in sport mode. Generally, I keep my car in sport mode at speeds below 50 mph and treat the normal mode as a overdrive.
Old 08-13-2015, 05:36 PM
Torrid's Avatar
I might try that today. Mine's a bit jerky in first sometimes.
Old 08-13-2015, 08:18 PM
Torrid's Avatar
Yep, confirmed the same for me. Much smoother in sport.
Old 08-13-2015, 10:51 PM
Excellent, thanks for confirming.
Now we REALLY need to know why and one of you software gurus need to write a reflash that mimics sport mode, but pushes into O/D sooner and stays per non-sport.
Get on that would ya (guru whomever you are ;-).
Cheers,
Jeff
Old 08-13-2015, 11:15 PM
Marque's Avatar
That's the ONLY issue I've really had with my car since I bought it; sport mode has never worked on it
Old 08-14-2015, 12:25 AM
nlt624's Avatar
When driving around the city I DO NOT turn sport mode off! The shifts are quicker and smoother.
Old 08-14-2015, 08:16 AM
Torrid's Avatar
It makes me think Jaguar was going for a slow soft shift and the amount of bloat between gears allows too much RPM drift which causes the roughness. Every other automatic car I've ever had never re-engaged first gear until the car came to a complete stop. It seems weird that it engages at 2-5mph when almost stopped.
Cheers,
Jeff
I was thinking this on my drive home last night. I wish we had plug in quick programmers. My 2004 GTO had a little slop between shifts and I was able to retune the shift points and up the line pressure. The shifts became crisp and all slop went away.
Old 08-14-2015, 09:42 AM
Torrid's Avatar
Just curious, but where is it stated that 6th gear doesn't engage in sport mode? I just tested it at above 50mph in sport and pulling the J gate into 5th resulted in a downshift. I also counted the shifts going from 0 to 60 mph accelerating at a normal driving pace and the car went through all 6 gears. As far as I can tell I can't see a reason to ever turn sport off, it feels like it shifts like ZF equipped BMWs I've driven. I love that it stays engaged and doesn't have to be re-enabled every time the car is started.
Nevermind, I see what is said, it has a tendency to drop down out of 6th more readily which would affect fuel economy. I didn't notice it doing that but I was on flat pavement.
Old 08-14-2015, 10:26 AM
Partick the Cat's Avatar
It's in the Technical Guide 2004-05, on page 95.
However Sport Mode is over-ridden by Cruise Mode which, if selected, does use 6th ... but I think the Sport Mode light stays on.
Old 08-14-2015, 10:37 AM
Torrid's Avatar
Good, then I truly have no reason to shut it off.
Old 08-14-2015, 11:14 AM
Marque's Avatar
All this "Smooth shifting, downshift, Sport mode" hooplah is making me,,,,,,,,,,,, being I have NEVER got to experience it!
Attached Thumbnails Anyone noticed smoother downshifts into 1st in sport mode?-2015-08-14-11-12-32.png
Old 08-14-2015, 01:30 PM
Torrid's Avatar
Why doesn't it work? Have you ever looked to make sure the button is plugged in?
Old 08-14-2015, 01:48 PM
Marque's Avatar
If I knew why, I'd have it working! Hahaha
But nah, I hadn't ever took the J-Gate off completely. I started to last week when I was switching out the Dash button controls. I'll take a look. Hopefully that's all it is. I've tried the whole "reset" thing to no avail...
Old 08-18-2015, 12:04 PM
VinnyT's Avatar
So, I am assuming the red light does not come on at all when pressing the button?
Old 08-18-2015, 12:06 PM
VinnyT's Avatar
I actually like running it hard in regular mode. The shifts between gears are smoother and it feels like a rocket ship. Sport mode is great but it is harsher shifting whereas regular mode is smooooth....
Old 08-18-2015, 12:36 PM
Marque's Avatar
Notta! No light or anything...
Old 08-18-2015, 03:05 PM
Torrid's Avatar
I think the red light is the only indication too. I don't think it pops up anything on the display when enabled from what I remember.
Quick Reply: Anyone noticed smoother downshifts into 1st in sport mode?
