Arm Rest Replacement
Hi Chris welcome to the jag forum. It looks like you have posted to the wrong forum thread - this one is for XJ's after 2010 (code name X351) and from your picture it looks like you have an XJ 2004-2009 (code name X350-358). If you ask your question there you are going to get more responses but in the meantime; it looks like your car has the auxiliary climate control package for the rear seats which has a different center console armrest to the bulk of the X350-358's which is why you are seeing replacements that look different. There may be a solution to your problem that will not need a replacement so have a look at the many resources on the X350-358 forum XJ XJ6 / XJ8 / XJR ( X350 & X358 ) - Jaguar Forums - Jaguar Enthusiasts Forum
There is a great how-to sticky https://www.jaguarforums.com/forum/x...k-links-20085/ and for your issue download the workshop manual body section http://redirect.viglink.com/?format=...Forum&txt=Body
and look at 501-12 which describes removal and installation of the console. Also search that forum for armrest lock.
Finally set up your signature with details of your vehicle which allows forum users to best identify your issue and offer help. Good luck
Don B (02-18-2017)
Hi Chris,
Welcome to the Jaguar Forums. It's great to have you with us.
In order to provide the most helpful replies, please let us know the year, model and engine displacement of your Jaguar.
And please visit the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post a required introduction so we can learn something about you and your Jag and give you a proper welcome.
Cheers,
Don
Cheers,
Don
AD2014 (02-21-2017)
Hi Chris,
Looks like your front latch is MIA, as well as the cup holder cover. The latch panel is easy to install. Part number: C2C34128
For example:
2004 Jaguar XJ8. #C2C34128: Center Console Latch. Latch. Front; CONSOLE BODY
For example:
The following 2 users liked this post by veffremov:
Chris Aragon (02-19-2017),
Don B (02-18-2017)
The following 2 users liked this post by woox4:
Don B (02-19-2017)
