Arnott\air suspension hybrid?
Additionally, I doubt you will be able to replace one axle with coil overs and keep the other axle air suspension. The car will start throwing all kinds of fault messages because it will expect to see the front rise/fall as it commands the air pressure to change. The coil over requires you to remove the complete air suspension setup.
I have an original comfort air strut that you can have for shipping if you want it. My RF developed the top seal leak last winter, I replaced both fronts with new Arnotts. The LF did not seem to have any issues. It is OE with 92k miles, and I felt the shock portion was a bit worn out. But if it helps, you are welcome to it.
The following 2 users liked this post by etaent:
charliepace (01-31-2016),
jackra_1 (11-02-2015)
Chuck Schexnayder
10-30-2015 11:55 AM
Sentinelist
10-29-2015 08:07 AM
