Arnott Coil Conversion Kit
#101
#102
#103
evilfij (09-06-2012)
#105
i unplugged my asm and i still have the "cats" warning light come on. do i need to do a hard reset to get rid of the code? i cant hear my compressor come on anymore since i unplugged the unit behind the back seat. I used to hear a hiss when i still had everything hooked up after my coilover conversion.
#106
It sounds like you followed the instructions for dis-connecting the computer found in the manual: http://www.arnottindustries.com/file...694&Size=SMALL
Go ahead and disconnect the battery and leave it unplugged for 1/2 hour. If that doesn't fix it call Marvin here in Arnott's Tech Support Department at 800-251-8993.
#107
Hi, Can you tell me how the new Coilovers work for you? Most of the postings are several years old. I know Arnott has re-engineered their coilovers. I basically drive my car only on long trips on the highway. Do you have any loss of comfort with the coilovers vs. the original air suspension. My 2007 Vanden Plas has also had a lot of front suspension issues with the stock Jag air. I understand the car will dip in the front a little upon braking hard and raise in the front during hard acceleration.
Any help will be appreciated.
Karon Mason-Etienne (07-12-2019)
#108
I find the ride comfort in a straight line the same as my sports shocks for the XJR. I do find that the handling around fast corners a bit more vague and I think it's because of the loss of the CATS capability. I don't notice anything significant for braking or acceleration. I changed my set as I just couldn't put up with the frequent error messages and the constant uncertainty of whether or not a leak would occur.
For an 07 car, you would need the Arnott's set due to the need for their electronic module that eliminates the error messages after the conversion. The earlier cars don't have this problem.
The following 2 users liked this post by klfong:
DanJensen (05-31-2015),
#109
Regarding driver-activated headlight auto-adjustment, does the headlight system in the 1973 Citröen DS21 count? Headlights would automatically re-adjust themselves vertically when the driver selected a different ride height. And, when cornering with the high beams on, the driver's turning the steering wheel caused the high beams to swivel left or right, illuminating the part of the road the car is steering toward. And the whole system was mechanical!
#110
Received 13,205 Likes
This thread on air suspension coil spring conversion has had no activity for over four years - is this the thread you intended to reply to?
BTW, Don't forget the "Cyclops" center headlamp on the 1948 Tucker that aimed left and right as the steering wheel was turned.
Also, some very good friends of mine are Mulvihills - there aren't a lot of you around so you're probably related.
Cheers,
Don
The following 2 users liked this post by Don B:
AD2014 (05-01-2019),
MountainMan (05-03-2019)
#112
Do a google search for more-recent / more active threads. There are many.
Also videos, Arnott-produced and not-only.
Arnott's approach has changed over the years. More than once.
Arnott goods mean Arnott should be the first place you ask, really.
Not as if they've never dealt with this. More than once.
#113
Take note of what Don B posted, just above.
#114
Not I.
My kid Brother is the published poet.
Been know to do a mean address to a Haggis, though...
... blame it on the Speysides as reward.. Scapa.. Old Pulteney.. .
#116
hey, actually I got the Unity 31-111700 Coil Spring Conversions Kit Front only. they supply the module, but no instruction. today I found the way to do it. the whole 9 yard of it.... take off the back seat etc. so I'll wait for the right mood to start this project. in the mean time, the car is flying just Great!
#117
I bought a cheaper MaxPeedingRods set of FOUR Chynee coilovers . $289 + tax for all 4, IIRC? But .. only as temporary 'fallback" if my OEM Bilsteins really ARE toast. Didn't even have to translate from Chinese. Foxy buggers sent multilingual instructions. No module required, my Model Year if doing all four corners. Just de-power the OEM box that rats-out a fault so it can no longer do so..
...but I weren't so cornfused as to ask about ARNOTT advice for a product not even the same race, tribe, religion, nor political DNA.
Mayhap your ARE "the reason.." [@ wfooshee .. and not-only - is] "...so far above average"?
#118
Does Unity claim their module will fool the ASM so it continues to operate the rears?
Don
#119
#120
If not readily restorable, I'll see if coverage on the MaxPeedingRods coil-overs is of use.
But no, from those who've posted over the past many years it isn't, really, a "bad thing"' to keep rear air struts, as it retains load-leveling.
Load-leveling is an independent feature in its own right - found on luxury cars for easily 75 years, already. Not to mention passenger coaches.. and trucks, trailers, and RV's.
Given the height-sensors are still there, it's more the missing modulated shock absorbers that want some form of "lie" crafted to feed the "con puta" box.
