Attention,there's an issue in SDD, be careful while doing wheel alignment.
Starting from v.134 SDD may not switch an air suspension in transport mode on a particular vehicles.
While doing a wheel alignment the suspensiom MUST be in transport mode or you'll mess the angles. If, while performing an alignment you'll see a strange measurements after doing some adjustments (i.e. mine castor was decreasing from 7' to 1' and will not increase even after a full turn of an adjustment nut), stop the procedure.
The workaround is to perform a wheel alignment while an engine is running.
The following 5 users liked this post by MoscowLeaper:
Clamdigger (07-28-2014),
Don B (07-26-2014),
lcmjaguar (07-27-2014),
meirion1 (07-26-2014),
Xag (07-26-2014)
hafren
08-30-2023 03:42 PM
