Auto Gearbox Concerns
Hi everyone,
My first post so thanks in advance for your feedback.
My 2003 Xj6 has developed an issue whereby when moving off it will spasmodically hang/jerk between what i think is 2nd and 3rd gear - then eventually it changes down.
On one occasion it held in one of the gears and then the gearbox warning light came on. I switched the engine off and the warning light cleared and the gearbox returned to normal.
Any thoughts would be much appreciated - the car has done 60,000 untroubled miles!
It likely needs a TCM reflash (software update). Also it will help if you replace fluid and filter. I had similar in 2011. There is a fault detector that detects pressures generated whilst changing; if out-of-limits, it flags a fault and puts car into 'Limp Mode'. It was explained to me at my local main agent that normal wear in the gearbox can result in excessive ratio-change pressures giving rough changes and eventually a fault flag.
Why we have to have this excessive complexity only Jaguar and ZF can tell us. Give me a decent Borg-Warner BW66 3-speeder anytime !!
Philip13 (04-21-2014)
Thanks again for the feedback but just wanted to correct an error on my part ie the issue occurs when the gearbox is moving upwards ie from second to third - rather than downwards ie from third to second.
Would this make any difference to your view on the likely problem?
Fraser
Philip13 (04-23-2014)
Received 9,010 Likes
Other than the dealers there are 2 transmissions specialists that may be able to help, Bristol Transmissions and Mackies Transmissions in Glasgow.
Mackies is THE A rated ZF partner in the UK.
Not sure about Bristol although they can probably help I'm sure, possibly a service, filter / oil change and a re flash will resolve your issues?
Why not call either and see what they say...........free advice perhaps.
Just a thought...
Just a thought...
