Auto Headlights always on
I am new to the forum and I have an 04 VDP and my headlights are always on when set to auto. Is there a fuse or something I should check before taking to dealer. I have just turned off the lights for now but would like to use the auto feature if possible. I have heard that the light sensor is in the rear view mirror and may be the issue. Any suggestions on things to check before paying dealer to check would be appreciated. I have only had the car for a month and love it. Previously had an S-type and also great car.
I use the Daytime Running Lights in my XJR, they only come on when you are in a gear or neutral, in park they are off...and it's only the headlights that come on, no rear lights, and you don't see the green "lights on" indication on the dash either.
In the X-Type i've put some black tape over the light sensor in the rearview mirror, so the lights come on automatically all the time with the switch in auto (poor mans DRLs...) maybe previous owner did that too?
Or it could be that your car is Canadian spec with hard-wired DRLs...?
Update on the headlight issue, it seems my lights were always on. The dealer says I need a new headlight switch. He also advised me that when the blinker was on, the tail light on the opposite side was also blinking. So, how difficult is it to change the headlight switch? Is it a plug and play or does it require dealer programming?
Yes, I changed the switch. It was really simple. There are 4 screws holding the cover on the steering column. Once those are removed the cover pulls apart top and bottom. You are able to see the switch and it pulls out and the new switch slides in. I got the replacement switch from my local parts store. All has been well with the new switch and doing it myself saved me labor and the cost of the part from the dealer.
rentzoo
11-10-2015 04:56 PM
