auto transmission fluid change
Jag says unit is sealed and does not need fluid changed. They base that on the 100,000 mile warrantee. Do a search on fluid change in this forum. There is a kit available with 7 quarts fluid, filter, new pan and new hardware mentioned. I bought a kit and changed my fluid on a friend's lift. You will see smoother shifts as a result. I found it to have been worthwhile.
tommyknocker (12-06-2018)
https://www.jaguarforums.com/forum/x...ooting-191572/
The following 2 users liked this post by Partick the Cat:
Sean W (12-05-2018),
xylorex
42
02-06-2023 03:16 PM
Silver Panthera
09-09-2021 10:48 PM
harryf
07-29-2013 09:14 AM
