auto window/sunroof closing when locking via FOB
Folks, any reason why I can open all windows and skylight when unlocking with the FOB (holding down the button), but the windows/skylight will not close when I lock it with the FOB? I can do both if I insert the key in the door and turn and hold (open and close), but they don't close when I use the FOB and hold it down. Is there any programming or something I need to do in order to make it work? Or some sort of safety override that I need to turn off?
Thanks in advance.
Gordon
Thanks in advance.
Gordon
You guessed correctly, its a safety feature typically left deactivated for US markets. It can be turned on using the dealer software, either bribe you're jag service tech with pizza, donuts, or golf ***** during your next visit for an alignment, and ask him to turn it on. It takes 5 min. I, and a few others are fortunate to have the same software and a cable to talk to our own cars like the dealer. We've used it to lower the front and rear suspension, enable 'global opening', activated both driver and pass mirror dipping in reverse, clear tranny adaptions, etc.
Thanks in advance.
Gordon
Thanks in advance.
Gordon
https://www.jaguarforums.com/forum/showthread.php?p=764175
Some good info in the address pasted above. Seems like some can enable the global close....
slmskrs (07-10-2013)
I don't follow the logic that it is "unsafe" to hold down the key fob lock button to global close, whereas holding the key in the door to do the same thing is unsafe, especially since a release of either stops the close.
My dealer will surely charge me. I don't know if the independent guys have the ability to do it (I'll have to check), and somehow I suspect the SW and cable to talk to the car and configure it (and lots of other fun stuff) is either not available in the US (since we might hurt ourselves), or prohibitively expensive. So not something that will easily be reprogrammed...... I'll talk about it the next time I'm talking to my independent.
On a side note, what is the speed or other parameters that lower the car, and how much does it lower?
Thanks.
Thanks.
I think the "safety" point in global closing is that with the key in the drivers door, you could see a person's hand/arm/head or whatever (use your imagination here) sticking out an open window. With a fob you could theoretically close all while not being able to view every window. In our litigation happy society, stuff like this is the price we all pay. Sad times.
I recently purchased the Jaguar SDD and discovered the locking options. After some thought, I have disabled both universal opening and closing.
While it might make sense to some, I hadn't realized the vehicle would open itself up until one day when I came back to my car after carrying several boxes. Seems the key fob in my pocket was being squished by the boxes as I walked. I really didn't appreciate not knowing my car was sitting wide open like that, but that's just me.
Other options in the SDD programming deal with mirror dipping in reverse (both/either side), wiper after swipe, daytime running lights (Can or US settings), and a few other odds and ends.
I went out to my car to try this at 1 am on a cold night, but I really want this feature. Ran through the sequence a few times. No joy. I strongly suspect that, like the mirror dipping feature this one cannot be enabled by some "secret sequence" if anyone can disprove that and offer said sequence, I welcome the experience of being proven wrong.
Okay, this only succeeded in giving me false hope. Has this method of "programming" worked of anyone? I remain doubtful because a) it did absolutely nothing for me and b) if a user accessible method like this worked I would expect to see many references in the forums, as well as a few success stories.
That's all I got. If anyone figures out how to close it with the key fob please let me know.
Regards
Travis
99xk8guy
06-05-2023 06:28 AM
aholbro1
08-05-2021 05:02 AM
