Automatic wipers stopped working.
Stephen,
If your stalk is in the correct position as nlt624 mentioned and your auto wipers still don't work, check the electrical connector to the sensor, which is in the mount for the rear view mirror on the windshield. The base of the mirror is covered by a two-piece clamshell housing that you can carefully pry apart and remove. On our '04 XJR, the electrical connector for the sensor had vibrated loose.
Cheers,
Don
Cheers,
Don
If I remember correctly the sensor is fixed to the screen with silicone which
can deteriorate with time and become partly opaque.
There is a fix for this:
$6 fix for a $600 problem (BMW rain sensor), page 1
Really? Mine come on with the first drop of water. I sometimes have to turn them off.
Weird AUTO wiper function
Rather old thread but I have an odd problem: when wiper stalk is in "auto: mode I get intermittent swipes, but not full auto when the rain comes down harder. When I go to the third notch "low" I get regular speed but wipers slow down to about (2) second interval when I am at a stop. Any ideas what's up?
Intermittent wiper problem solved
Some folks had mentioned the connector behind the mirror as a possible culprit. Bingo! I had the headliner replaced a while back and it would appear the technician did not reconnect the rain sensing 3-wire connector. The housing arond the mirror mount was askew which makes me think that was root of the problem. Anyway, fixed. Thanks to Don B. and others.
The following 2 users liked this post by rsa760041:
joeldietzjr (12-17-2023),
Mac Philipson (03-06-2021)
I had this same issue. Turns out that the sensor, which is located right above the rear view mirror, is fixed into place with an adhesive that can deteriorate over time and obstruct the sensor. I just removed the sensor, cleaned everything off, and reaffixed it. Problem fixed! If you do need a new sensor, I've seen them for around 50-70 bucks.
I bought a new rain sensor for JX8 2001 and the adhesive that came pre-installed from the parts store doesn't seem to want to make a good seal to the windshield and keeps falling off. Is there any fix for this that wont mess up the sensor or should I check with Merriam Jaguar and possibly return it for a new one?
JP
JP
firstchoice
10-11-2015 08:15 PM
