Auxiliary Coolant Pump Bosch part number?
Can anyone tell me what the Bosch part number is that is stamped on the electric auxiliary coolant pump that's mounted by the radiator? I can only read the first couple sets of numbers: 0 392 020 ???. I've done a search, and it looks like the last 3 numbers could be 024, 039 or 044. The pumps look identical minus the mounting bracked to the pump that's on my XJR, and it can be purchased for about $85 - quite a bit cheaper than what I've seen online for the Jag part. It looks like I could slide the old Bosch pump out of the mounting bracket, and slip this one in.
I got that information at home since I replaced mine last weekend. If you do not get a reply back by tonight, I will post back.
One thing to remember is that there is the auxiliary pump and then there is the super charge coolant pump. The latter is a bit bigger and they both sit in the same vicinity, near the right hand side of the radiator (passenger side).
Yes the one on the right is the aux pump (Bosch)
Excellent photo here:
https://www.jaguarforums.com/forum/x...-108987/page2/
0 392 020 071
Yes, the one on the right is the auxiliary coolant pump and the one on the left is the supercharger coolant pump.
I found this link if it helps anyone: JCNA Forums - Jaguar Clubs of North America
But I'll probably just bite the bullet and get a new one. http://rcm-na.amazon-adsystem.com/e/...ins=B004JPZ46M
QuikCat (01-30-2014)
KarimPA
09-03-2015 07:32 PM
