Is auxiliary pump fitted
I have a 2004 xj6 3.0L Vin SAJAC71M14VG33903 with poor heater.
Assuming that the problem is either auxiliary pump or heater matrix I sought main dealer part prices but was informed that the pump is no longer available.
I purchased Auxiliary Coolant Flow Pump - 4.2L NA V8 - AJV8/4.2L SC V8 - AJV8/3.5L from jeep-chrysler.co.uk
The local garage was asked to fit the new pump but could not find the old pump.
Is it possible that an auxiliary pump was not fitted?
And if not, is an upgrade possible or necessary or will changing the heater matrix solve the problem.
Unless otherwise advised my next step is to revisit the main agents (with the Vin) to hopefully determine whether a pump was fitted or not.
It seems the 3.0 does have the auxiliary coolant pump. Here is the illustration from the manual that may help.
Pete M
3.0 L Engine cooling
Not easy to see if you have the Bosch pump.
Put your arm down between the engine and the rad
and feel for the pump.
https://www.efisolutions.com.au/bosc...RoCoHYQAvD_BwE
Usually when the matrix is blocked or partially blocked the driver's side is cold
and the pass. side is warm.
Avoid main dealers if possible
There can be a number of faults causing the problem:
Water pump with plastic impeller failed
Plastic manifold broken inside and part blocking flow
Failed t'stat
Failed t'stat
Failed t'stat
Failed t'stat
I may have to get back to you on 'plastic manifold'
I suspect that during development and test it was found that insufficient hot water flowed through the heater matrix - so an auxilliary pump was added to increase flow.
I understand that this pump runs continually and after 100k+ miles the brushes wear down.
Gary7 (12-25-2023)
The pumps, either the main water pump or the auxiliary, are not there to generate pressure, but to generate flow. The pressure comes from the temperature as the coolant heats up. There is a fixed volume allowed for the coolant, and as it heats up, it wants to expand, and with no place to expand to (other than the space available in the expansion tank,) it builds pressure.
The above was my understanding of the auxiliary pump's purpose, simply to increase flow through the heater core. I didn't think it ran constantly, but I really don't know what conditions cause it to run.
