Battery Red Light
Old 12-12-2017, 05:08 PM
jackra_1's Avatar
Received 1,756 Likes on 1,327 Posts
OEM branded alternator purchased elsewhere.
Any Jaguar/Ford dealers give discount to Forum members?
Old 12-12-2017, 05:48 PM
jackra_1's Avatar
I am looking at Jaguar Merriam Parts to order an alternator for $660 no core deposit.
Old 12-12-2017, 06:38 PM
Sean W's Avatar
Received 4,222 Likes on 2,368 Posts
Jack did you give a call to SNG Barrett, Coventry West?
Old 12-12-2017, 07:16 PM
jackra_1's Avatar
SNG Barrett quote on-line $730 plus a $240 surcharge!!!
Coventry West want $638 plus $244 core charge.
So Merriam looks pretty good.
Old 12-12-2017, 08:35 PM
Received 1,423 Likes on 1,066 Posts
Don't laugh but why not look for a unit from a wrecker? I actually did and scored 2 good alternators, one for my 00 and for the 04 XJR.
Just in case... (I actually need to resell the 00 alternator)
Old 12-12-2017, 08:45 PM
Lagonia's Avatar
That is exactly what I would do. I have done many a trip to my local salvage yards in my quest to make my 87 Merc 560 SEL yet another daily driver and have scored some hard to find parts for cheap. Granted, I never see X350s in the yards - ebay may be another option.
Old 12-12-2017, 08:53 PM
jackra_1's Avatar
If there was a wrecker near here I would do that.
It is like the alternator rebuilder I found an hour away that ended up saying they could not rebuild my alternator.
I am not near anything of use here in MD !
I was even considering buying a used one off Ebay however the ones I looked at were pretty high mileage. Way over my 106,000 that I have on mine.
I placed the order with Merriam so hopefully it will get here soon.
Now I will "extract" this alternator over the next 2 days in frigid temps!
At least I have it down to an exact science now.
  #28
Old 12-13-2017, 12:56 PM
jackra_1's Avatar
This is what I am getting from the Ebay alternator seller.
"The seller sent you a message
MessageI am glad you mentioned it. We have had this issue before, the battery has to be a original Jaguar battery or the voltage will remain low. We can guarantee if you buy and install a new battery from the jaguar dealer it will bring the voltage up to 15.1 it has happened to us countless times before".
Old 12-13-2017, 05:14 PM
Box's Avatar
Box
Box is offline
Please check also fuse F30 (10A) in the rear power distribution fuse block, as well as fuse F33 (5A) in the passenger junction fuse box.
  #30
Old 12-13-2017, 05:55 PM
jackra_1's Avatar
I have already done that and they are fine David.
The seller on Ebay has accepted the return.
Merriam have told me that this Jaguar alternator I have ordered will take 7 business days to arrive plus there is a core charge of $240 that was not stated on their web site.
  #31
Old 12-13-2017, 06:21 PM
I would try national online wrecker sites. I've used them before and recently I scored a center console assembly (with rear HVAC) for my XJR.
I know it's not an alternator but with a bit of searching you might save hundreds, literally..
Narrow down to your VIN range.
  #32
Old 12-13-2017, 06:23 PM
That's a BS response...
What they meant to say is "original Jaguar alternator".
Battery brand will have zero issue and not cause the battery light to illuminate.
It's the proprietary parts inside the original factory alternators that causes this issue.
And 15.1V is too high anyways. Clearly they don't know what they're talking about.
The following 2 users liked this post by abonano:
jackra_1 (12-13-2017), Sean W (12-13-2017)
  #33
Old 12-13-2017, 06:58 PM
jackra_1's Avatar
That what I was thinking.
Now to uninstall this alternator and ship it back.
  #34
Old 12-13-2017, 10:44 PM
Mark in Maine's Avatar
I second the BS response. They obviously don't know that the current Jaguar dealer supplied battery is junk (my dealer confirmed), and cannot handle the high charge rate of this car for long. Doesn't the BCM in a way control the charge?
  #35
Old 12-14-2017, 06:33 AM
jackra_1's Avatar
I did not know that about dealer supplied batteries!
I do think the BCM controls the charge which is why voltage output is higher when cold as opposed to when the engine is warm.
Ok just read Box's post on another battery thread and it is the regulator that controls the voltage.
  #36
Old 12-21-2017, 03:41 PM
jackra_1's Avatar
So installed the Jaguar OEM alternator from Merriam and the battery light still comes on.
I am getting 14.25 volts at cold idle across the battery terminals. Thats significantly higher than the last alternator.
On my 2013 Range Rover I get 15 + volts at cold idle.
Anyway this is it as I am darned if I know what the issue is. I will use my iCarsoft 930 tomorrow to see if that pulls anything and then I will run the JLR SDD software.
However I know its charging and I will get used to seeing the battery red light.
  #37
Old 12-22-2017, 06:02 PM
Sean W's Avatar
Yep, it looks like you're down to this:
jackra_1 (12-22-2017)
  #38
Old 12-22-2017, 06:11 PM
jackra_1's Avatar
Or disconnecting the bulb!
Went for the first drive in a long time today. Power is all there and did not notice the red battery light.
  #39
Old 12-23-2017, 08:44 AM
Wingrider's Avatar
Don't know what to think about these cars on occasion; They do act more than a bit different from any other cars i've ever had. Was putting air in the new to me 2007 VDP's tires, the caps were on very tight. Air in three tires gave three different pressures, the forth one was made of steel plated with chrome, & rusted in tight enough to break the stem when pliers were used to try to remove the cap. The spare had a sensor in it, which then turned the check the air pressure in left rear tire out in less than half a mile. Told me to check the pressure in spare tire in the trunk, which is a good thing to remind you of in case you forget. The new sensor installed in the wheel, took about three to five miles to turn the yellow tire light off. Put the same spare back into the trunk, bolted it back down, just like before. The same warning is still coming on EVERY time the car is started, for several seconds to remind you to check the pressure in spare tire. (W T F?) Figure it will eventually clear itself, too bad i do not know how to clear it from reminding me to address something, addressed already!!!!
  #40
Old 12-23-2017, 10:15 AM
Box's Avatar
Box
Box is offline
At this point I would insure with SDD, what the ECU is seeing. Also, I would do point to point testing of the leads. One of the issues with our series' charging system, (4.2l) is that many of the replacement voltage regulators, if not specified, may have N/C on terminals which send voltage to the ECU. Just sayin'...
