battery replacement tricks
I'll be taking the 05 XJR North for Christmas. It is a Florida car with the original battery. It so happens I have a spare battery that I can carry along in case of cold weather failure. The current battery is good but it has some age and has never seen a cold day.
It used to be that one could change a battery without losing stored code info buy pugging a small 12V source into the cigar lighter before removing the battery. Is that a workable solution with modern Jags?
The reason I ask is there seems to be a lot of stuff dependant on the battery in this machine and I'm not sure this old trick is still valid.
The Battery in the cigarette lighter technique is known to me. In fact I have used it successfully a few times in the past.
What concerns me is that these cars have so much memory stored here and there that a 9V battery may not might not be up to the task.
Has anybody here actually successfully used a 9V battery on a 2000 or later Jag to save memory during a main battery exchange?
I bought a 9v memory saver device for mine a while back but havent used it yet.
If the worst came to the worst cant you just press A.Mem, PTY and >> to get the radio code (as long as its the radio from the factory) and press and hold eacj window switch for 2 seconds in the fully up and then fully down positions to re-enable the one touch window open/closing?
Thing that concerns me the most about trying to preserve memory with a 9V battery during a main battery removal and replacement is not just the radio. I was thinking about the seat, pedal and stearing wheel memory. Not to mention the cars system set up and nav. settings.
I,m not really sure how all this memory is retained, but it seems like a tall order for a lowly 9V source. That's why I was interested in hearing from someone who has actually tried the 9V batt. It seems to me that we do have an answer, in that one poster said his dealer uses a "batt. minder" to provide the power during batt. changes. My guess is that a quality service dept. takes no unnessary risks.
Charlene n John
09-28-2015 06:01 AM
