Batttery Lifespan?
I bought a 2004 XJR in March of 2014 - it had 36,000 miles on it - and what looks like the original battery. It was garaged through the winter, and didn't get out much. I tried to take it out on dry days every week or so, but then I let it go for about 3 weeks (lots of snow, salt and rain), and when I did go to drive it, the battery wasn't strong enough to start the car.
After jump starting it and driving it, it seems fine for the last 2 weeks, but now I'm worrying that the battery is weak and on its way out - after 11 years. They use big beefy batteries in XJs - but I don't think I've ever run on an 11 year old battery on any other car. I also have an '03 X-type, which had its original battery for 9+ years (also a record) before I had to replace it.
So how many of you folks are running on a 10+ year old battery?
Don B (04-16-2015)
Received 9,010 Likes
Don B (04-16-2015)
Received 13,107 Likes
Our '04 was 9 years old when we purchased it and it still had the original Varta battery. I replaced it preemptively because I suspected some phantom trouble codes were due to insufficient battery voltage or current under load.
Jaguar saloons require a strong, healthy battery, so I agree with Cambo and Jim that you're on borrowed time. It stinks to have to replace a battery while traveling (with whatever brand you can find, usually at an inflated price). Better to do your research, shop around for a good price, and replace the battery at the time and place of your own choosing.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Cheers,
Don
Cheers,
Don
I know that my battery for the '05 XJ8, bought in 2009 and now at 40,000 miles, is probably on it's way out. I keep it on a battery tender from Harbor Freight because we don't use it often. I have a 2001 Honda S2000 (#82), 10,000 miles, also. Both batteries are still strong and I hope they stay that way for more years. When they start to show problematic weakness, I will replace them. I guess I will be that old guy who drives around in a near mint classic car.
Mine had the original silver Varta, badged Jaguar, just under ten years old. I was not using it much through winter, and it went too flat to start the car after about six weeks.
The Varta part no has changed, I emailed them for the new number (mine is the 100AH version) H3. It is quite long and heavy.
My local motor factor quoted £120 but I got one online for £84
When I bought mine in July 2012 the battery was from march 2006
I bought a new one last year even though it still worked fine
The battery in my XJR6 died on the Ctek charger just after it was 3 years old it might have been recoverable because the Ctek charger died (Got a new one under warranty)
I had just sold the car to a guy in Tasmania that week and was driving it there to be delivered didn't want to take any risks bought a new one
I thought I would take the new one from the XJR6 swap it with the X350 and that way have a new battery again no such luck X350 battery is huge 1000 cca XJR6 800
I replaced the factory original battery on my 04 XJ-VDP when the car was only a couple years old when it started giving me random electrical problems. I'm still running on the replacement battery with no apparent issues, which I got at the time from a Jag dealer. The car has ~60k miles on it now. I'm guessing the battery will need replacement soon.
Exactly what happened to mine before battery died with a full boot ( trunk) full of luggage why did they not put a jump start point under the bonnet ( hood )
Ipc838
09-13-2015 03:27 PM
PinnacleWax
Detailing / Car care
08-06-2015 11:51 AM
Auspuff
05-31-2015 07:42 AM
VIAPA2
08-27-2014 08:46 AM
