Black Window Trim for x350
Black has been an alternative on 'Sport' and 'R' models in Europe going back to the X300. Originally on the X300, the standard chrome/stainless trims were factory refinished with satin black as on my X300 here:
![Black Window Trim for x350-x300-last_2.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/55507d1480969716t-black-window-trim-x350-x300-last_2.jpg)
On later models, the black trim base is steel or aluminium with a primer and finished in satin black like the XK8 in my SigPic.
There have been many complaints about the black finished trims on a number of later models. The problem is the paint bubbling due to inadequate priming.
You could be better off staying with the chrome/stainless trims and having them polished.
I think what you see is the door frame, it is black and along with the tinted windows and white body, the trim blends in and appears black.
I am thinking of using a black wrap such as this:
Chrome Mirror Black Car Auto Sheet Wrap Decal Vinyl Film 6" x 60" Air Free | eBay
or
http://www.ebay.com/itm/3M-1080-Scot...0b97aa&vxp=mtr
or
QuikCat, if you are referring to the front windshield trim, then you might be out of luck. Jag used a "chrome" trim piece around the windshield for 2004 model XJ's, and if I remember correctly, completely removed that trim either for the start of 2005, or sometime during the 2005MY.
I've worked with vinyl wrap and I can tell you it would be difficult to get it to stick to the edges of the trim. My son and I have wrapped a hood and various trim pieces inside his car, and if there are any compound curves, it is difficult to get it to stick. Using a heat gun helps, but unless you wrap it all the way under the trim, I'm guessing it would start to lift.
I wonder how much a UK dealer would charge to ship to the U.S. if I were to order the trim pieces from an authorized dealer?
Quebecjag
09-10-2015 06:06 AM
1964Daimler
09-09-2015 11:28 AM
