Bleeding the brakes
You should not have to bleed the brakes ever unless you are doing a brake job. If your brakes are spongy and you feel air got in them, figure out what happened and address it first.
Panelhead (01-30-2016)
That is what I had decided.
Yes, pull the wheels. I do it the old fashion way. Wife in the car pump, push, bleed, let go, repeat, make sure your reservoir does not run out of fluid. Right rear, Left rear, right front, left front in that sequence.
I use a power flusher. Cannot get anyone to pump the pedal for more than five minutes. With the power flusher it only requires pressuring up, and opening the bleeder until clean fluid comes out the passenger side rear, then the driver side, and up to the front.
A tip re the use of a power bleeder. When you open the bleed nipple be sure you are not sucking air via the threads. This is not a problem with the 2 man procedure but it certainly is with power bleeders.
When you have completed the flush steps, go back to any rear wheel and ever so slightly do it again followed by a diagonal front, followed by the remaining rear wheel and remaining front wheel in order. This because the braking system is a "dual diagonal" system. If you don't follow this procedure you will have a hell of a time getting rid of a spongy pedal.
tomfurie (02-21-2016)
Dickie_L_J_O
02-05-2016 07:50 AM
FS[Central US]: 2004 xjr $ 9500.00
belladad
02-03-2016 08:09 AM
