Blinking Display screen
Every once in a while my center console display screen goes blank (and I dont mean the dimming of the contrast like when the auto headlights go on) for about 5 seconds then comes back. Every function works but I am worried about this. Is this a common problem? What causes this? I have been suspecting my RCCM may have a problem because of odd climate control issues. Is the display controled my the RCCM?
I suspect you are seeing the back light turn off on the display. This will also trigger the colors to go into night (black) mode
You need to confirm if it the wiring to the ICE or the Auto headlamps issue
Tru running with auto headlamps off and see if the problem goes away
If it does it's most likely the stalk or the sensor
If not it most likely a connection issue to the ICE
34by151
34by151
Finbarr1975
09-16-2023 02:52 PM
