Bluetooth
I Have a 2007 XJ8 VP and I have been reading comments and forms about Bluetooth connectivity my
problem is that the connectivity is intermittent!
sometimes the phone connects immediately when I get to the car and sometimes I have to force the connection thru the setting on the phone several times up to 15 minutes before a connection can be established
I tried a different device with no luck
I uninstalled the device several times pushed the phone button on and off but no luck
watched YouTub for similar issues any advice from the x350 owners?
As I don't have the X350 anymore, bear with me. Is there a time out to home screen when you're on the phone screen? In other words, does your Jaguar give up after a short time trying to find a phone?
On the XK, there is a timer and after so long, the phone screen stops trying to connect. To alleviate this, we simply extend the time out to a longer period. This is in the systems or vehicle setting. I don't recall which and like I said, I'm not sure it's relevant to your make/ model.
