Bluetooth issues
Bluetooth issues
Not sure if this is an iPhone issue or a problem with the car system. I use the bluetooth from time to time and it has always worked.
Yesterday I tried using it and the phone kept timing out before i could get the PIN entered. finally I got it to work and made about 10 different calls. no one could hear me, but I could hear them. Then the phone kept disconnecting and finally I got the message No BT phone.
Was going to try pulling fuses this morning but entered the code ##1#*# and the Discover ME message came back, I deleted the Jaguar from the iPhone and re-added it and was able to successfully pair the phone, however, people still could not hear me, then the No BR phone message came back.
Ideas?
Ideas?
I believe I have found a solution. If I turn on Bluetooth on the iPhone before I get to the car and leave it on all of the time, it works every time. The problem seems to be when I turn it on after the car has already been started.
This also seems to affect how the car retains the phone's contact list because now I also always have access to it from the head unit.
And it works flawlessly through Pandora, when a call comes in, Pandora fades & pauses until I accept or decline the call.
Mist be something to do with the iPhone 4 Bluetooth, because I never had this problem with the iPhone 3Gs.
