Bluetooth pairing
If your car is Bluetooth equipped, you would be able to pair the phone to the car. When it says "NO PHONE", that usually means that the car isn't Bluetooth equipped and it is looking for a hard-wired phone to have been installed.If your car IS Bluetooth equipped, here you go:
(1) With the Phone screen on, the key turned in the ignition, press ##3#*# and then press the making call button. It should then say "Discover Me" or "Pairing".
(2) On your phone, go to Bluetooth settings and then look for Bluetooth on.
(3) Then locate/discover devices. When it has found "Jaguar" on your screen, pick "Jaguar" and it should ask for passcode or PIN which is 1313
(4) Then go to authorize the "Jaguar" device on your phone. That should get it connecting automatically each time you leave and then re-enter the car.
(5) After you pair the phone to the car, the phone ask you to authorize access to your Contacts to the car. If you say "OK", this will allow the Jaguar radio to scroll through your phone contacts with the names and phone numbers showing. I read somewhere that the Jaguar phone module can hold up to 500 names and numbers.
The following 2 users liked this post by rtraphan:
Mark Ide (06-15-2020),
Threeducs33 (02-20-2024)
davealberta
09-18-2014 08:33 AM
