Bluetooth Phone Pairing
I have a 2006 VP loaded with DVD...etc. When i push the telephone button to try to pair my bluetooth phone to the jag the touch screen states "car not fitted for telephone". This seems odd since it appears every technology piece available in jag is in my car.
I would really appreciate any suggestions on how to get to my bluetooth pairing. I have the owners manual and can follow instruction but cannot get off to a start with the process.
Thank you in advance!
There should be a small Bluetooth microphone just to the left of the sunglass holder. This thread has a picture of what it looks like. It was for an S-Type but the location is the same.
https://www.jaguarforums.com/forum/s...uetooth-28542/
If you press the phone button on the steering wheel and it mutes the radio,CD etc, you probably don't have the phone BT adaptor or voice command module fitted.
This I have gleaned from reading the multitude of threads on a similar subject in this forum.
Although I have been known to be wrong (many times to be exact!).
http://m.ebay.com/itm/Newer-Factory-...200?nav=SEARCH
(Not my add; reference only)
Early setup required phone module plus Bluetooth module plus microphone and addition to optical loop
Later setup combined phone and Bluetooth into a single unit. Still need to add a mic (unless car has voice) and likely need to add to the optical loop.
Thanks-
Mag
Thanks-
Mag
Thanks-
Mag
Thanks-
Mag
Thanks,
Brian
